Author Topic: Plate cell by stevie1001  (Read 15399 times)
  • OO-Rah!
Re: Plate cell by stevie1001
« Reply #24 on: August 20, 2008, 15:15:20 pm »
Nice to see it running.
If you want to maintain your flow as you add plates,
you will have to raise your return up a little.
A taller reservoir.
Spike
« Reply #25 on: August 20, 2008, 18:43:32 pm »
A taller reservoir.
Spike
thanks.
I will keep that in mind.
At this moment i am a bit sad about the fact that lots of brown scum is attached to my plates.
steve
« Reply #26 on: August 20, 2008, 20:01:42 pm »
What did you use to clean your plates before instalation?
I was told to run vinigar thru my sistem and then rince twice then add tap water & power.
good luck
Robert
« Reply #27 on: August 20, 2008, 22:15:16 pm »
good luck
Robert
thanks for the tip
steve
« Reply #28 on: September 04, 2008, 22:57:55 pm »
Hi,
Oke,
It was today the start of putting all components together.
I know it took a while.....i had to do soooooo much by hand.
53 plates sanding
106 holes drilling
54 gaskets
and some more components.
Here are some pics for you.
Next step is to make my new designed bubler / waterreservoir.
« Reply #29 on: September 06, 2008, 01:07:30 am »
Hi,
Just fired the monster up.
As useal, i do not use destilled with chemicals, like KOH.
I just filled it with nice clean tapwater.
I got on my first quick test, 2 litres hydroxy a minute.
Did i prove enough......   ?
You should hear the sound of that unit producing......i am impressed.
A 3.26 MMW for a testdrive is not bad....
It will get better very soon, when i add my electronic tricks to it...
« Reply #30 on: September 06, 2008, 11:57:40 am »
Hahahahahahahahahaha,
I just got me 4.3 litres of hydrogen/oxygen in 1 minute   :) :) :) :)
steve
« Reply #31 on: September 06, 2008, 12:00:14 pm »
I just can not take that smile of my face..... :D :D :D :D :D :D
 :D :D :D :D :D :D :D :D
 WOWY
4.3 litres a minute without using any chemicals!!!!!!
CU
