Author Topic: SPIKE'S BURTHA CELL  (Read 30755 times)
keithturtle
Re: SPIKE'S BURTHA CELL
« Reply #8 on: July 05, 2008, 01:22:38 am »
Uh, the glue I mentioned in the plate cell thread probably won't be the best choice in this application.
CHeck the LORD Fusor tech team for the optimal glue. http://www.ellsworth.com/gluedoctor.html
If you aren't using any caustic e-lyte, you can use model airplane epoxy, and add polyester bulking agent to get the viscosity up.  CHeck with Atlanta Hobby or any hobby shop.   Use 30 min to allow plenty of set time.
If it's simply a matter of sealing threads, Goop marine is tops, and it can be taken apart later whilst epoxy has to be heated beyond what yer PVC can stand to make it let go
Turtle
  • OO-Rah!
« Reply #9 on: July 05, 2008, 06:03:26 am »
Thanks Turtle
I'll check into that other glue.  ;D
Spike
  • OO-Rah!
« Reply #10 on: July 05, 2008, 06:12:35 am »
 ;D The basic cell is done  ;D
I still have to wire it,
And get the plumbing installed.
I haven't glued the collars yet,
until I finish everything else.
But here is a video
http://www.youtube.com/watch?v=uIzvnRJx9-E
And a picture of why I named it Burtha
Spike
« Reply #11 on: July 05, 2008, 06:13:28 am »
The glue I used on my latest cell is Plexus MA300 Methacrylate it is a very permanent bond. I pressurized my cell to 120 psi with no leaks. I got mine from a battery plant that I do refrigeration for.  I found this link for it. http://www.gluguru.com/Methacrylates.htm#ITWPlexus.
  • OO-Rah!
« Reply #12 on: July 05, 2008, 06:44:36 am »
thanks Karebill
I'll look it up. How long have you been using it?
Spike
keithturtle
« Reply #13 on: July 06, 2008, 04:58:07 am »
Nice work on the cell, spike.  I see yer bare hand on the tubes.
Transfer of skin oils will introduce anutha variable into the cell and may cause foaming.
The LORD fusor system is methylacrylate as well.
Keep at it, man!
Turtle
  • OO-Rah!
« Reply #14 on: July 06, 2008, 05:49:24 am »
Turtlle
I usually wipe them down with alcohol last,
To remove any oils left over.
But I do touch them on the ends.  ???
I'll keep this in mind.
Thanks
Spike
keithturtle
« Reply #15 on: July 07, 2008, 04:33:52 am »
My quick-shot passivation is Citrisurf 2050
http://www.stellarsolutions.net/2050data.htm
I don't have much problem with rust i nthe cells.
Turtle
