Author Topic: Self Running Water Pump And Others  (Read 2624 times)
« on: December 06, 2024, 05:03:35 am »
You Tube Video--   I make free water pump no need electric power new style;
The 2 side water levels are equal, therefore no siphoning self running effect.  I am assuming there is a Lithium powerful battery inside the DC low voltage pump/motor side housing that is connected to the 2 plugs. The end shaft is also turned ,- the 2 electrical contacts connect, for the plug on the positive side, running the water pump. (acts like a jumper connection)The Pump stops when plugs disconnected,- for open switch state. He uses the drill power to overcome initial inertia , as pump is off when first plugged.  There is also some momentum saved. It takes lots of electricity to run an electric motor Watts of power. This however, could really be a great invention after all. Ac 220v generated same time as pump motor runs.
 Also, a DC permanent magnet 12v car heater fan motor can be used to run a transformer . Transformer will run on either AC or pulsing on + off DC, but not DC.  By opening housing, snip wire section on each side 180 degrees apart on armature. Put back together. Run on oscilloscope top see pulsing square waves or hook motor to transformer to get a secondary voltage output. There will be ohms resistance in series from the motor wire. Turning shaft will produce on/off signals from wires output- running backwards.
Back in the 1980's I saw an air compressor running by itself and used for mowing grass by pushing piston of mower with long hose out the window of trailer.. Retired carpenter had air tank with balanced SPOKED TYPE flywheel on main shaft with reciprocating hydraulic cylinder on journal of compressor shaft. (no motor, wires, battery) A preadjusted vortex tube heat shielded, had increased pressure of heated air to the cylinder keeping crankshaft going. He had 3 machined parts from 3 different machine shops , so as no one knew what final assembly was. 40lbs initially filled tank by hand rotation flywheel, until self powered.
Man from Georgia ran his riding lawn mower engine on salt water in carb 2008. See Youtube videos S1R9A9M9 . Hidden 300watt Inverter box in rear hole of cement block. Battery start. battery removed. Engine ran on hydrogen from spark plug electrolysis of salt water. Alternator under flywheel has 12 magnets powering the conversion .Bridge rectifier  about 11 amp draw for inverter to 110v DC and about 4 amps to electromagnet over plug wire to change to ATDC timing for hydrogen. About 15 amps total . Peak pulse current 7-10A, average current about 1A to plug. Self running Briggs 18HP at idle speed. . Tiny electrodes of zero ohms spark plug requires high volts.
Mr. John Keely of late 1800's machine shop Philadelphia, had demonstrated self running rotating motor mechanism that had flywheel and band saw sawing wood for visitors,  and investors. Hydo pneumatic vacu engine. It had rotating 4 way shock valve that created internal pressure 50 lbs of water hammer.  Table top model is on Youtube that was stolen and later returned to museum. The Patent application showed it's workings. Full Patent not issued because Investor's names not on manuscript submitted. S.V.P. sells copies of old Keely documents.
Re: Self Running Water Pump And Others
« Reply #1 on: December 07, 2024, 04:43:59 am »
We had a water ram on a farm. It was very basic compared to a large Williamson pump.
Our one had brass components and 2 valves, no tank but it ran continuously day and night.
