Author Topic: why Stanley used Higher Voltage....  (Read 11573 times)
« on: November 28, 2023, 21:06:46 pm »
the higher the voltage, the faster the electrons move. This is because the electric field increases their kinetic energy.
Re: why Stanley used Higher Voltage....
« Reply #1 on: November 30, 2023, 00:24:48 am »
Yes… i think so too..
but the mean free path limit that speed dissipating…
« Reply #2 on: November 30, 2023, 08:51:41 am »
Yes, that true.
I think that the effect that we are looking for, is the electron avalance...
The old documents all state that we need to align the molecules first.
Thats the electrolysis part, even if it is just for a very short periode in thime.
Then the BEMF pulse from all coils involved come quickly afterwards and hit the electrons from the molecules, as stated by Stan.And there is the where the overunity effects comes from.
The electron avalance.
cheers!
« Reply #3 on: December 01, 2023, 18:19:07 pm »
I don't agree. Current is the number of electrons through a cross section per unit time. Stanley prevented the current, that is, made it less than 1 ampere.
For Faraday electrolysis, electrons are useful, so the current there is up to 20 amperes and higher. For Meyer's voltrolysis, electrons are harmful, so it was made at less than 1 ampere
« Reply #4 on: December 16, 2023, 14:52:54 pm »
He restricted but according to himself he had what he called a leakage current … and the output gas was a geometric progression of the current input! Meaning more than one conversion per electron used..
« Reply #5 on: July 26, 2024, 19:22:32 pm »
The tv episode Mythbusters - called "Exploding Pants" is purchasable, and is about running a car engine on vertical water cell hooked to the carburetor, was a deliberate NEGATIVE set up. I counted 14 built in mistakes to not allow engine to run on hydrogen. The electrical circuit that was to be used was really called  "The Hydrostar". The complete original design is on Internet for sale. I have paper manual , but it's now being sold as a computer disc. Mythbusters did not use proper design, nor did they implement the required magnetic wire coil. Even gas engines use air as part of the blend. Their carb was completely closed off. Real usable energy related material will never be shown on tv, local newspaper or on radio general news. You have to your own research and see what others have already done. The man who designed Hydrostar was one of Stan Meyer's technicians in Ohio before Meyer was poisoned . Chambers went to Canada and filed Canadian + US Patent on modified version of Meyer's work.  His Xogen company had showed a display of HIS unit for publicity. The magnetic field energizes the rising ions in solution and increases energy content. Circular concentric pipe electrodes are superior to flat plate electrodes. Pulse quick current only for ALIGNMENT of water molecules polarity. Then pipes hit with high voltage DC pulses for way overunity hydrogen and oxygen gas. (No electrolysis at all)- that's old technology as of now. The Patent pages don't state it but, if flipping drawings pages back + forth , you can see it's easily done as connecting the wires of pipes to the resultant flyback high voltage coming from the wire coil.  !!  Hydrostar US Patent 6126794 by Chambers as studied and read for free on Internet.
« Reply #6 on: July 27, 2024, 15:32:42 pm »
The old water car plans used this patent as a base… they use a toroidal coil over the cell pulsing in the plans
Very interesting that saint Clair says it can distort space time with this configuration
« Reply #7 on: August 28, 2024, 01:14:14 am »
Spectacular Meyer Cell Blows Away All Other Designs Of Making Hydrogen Gas!
The Stanley Meyer Patented hydrogen generator cell was the best method for generating usable hydrogen gas fuel from plain water ever invented. Efficiency % was in the thousands. (that means overunity) The several Patents have run out and are in public domain. This means you can study/ build cells. Don't listen to naysayers. Read/study the tech data for yourself. (no electrolysis at all) Small units for use or for blast furnaces of industry. There were 3 levels of this. Books - Birth of new technology + water fuel cell company manual. See what others have done as bench tested. A coined common expression had been given for this as -- Voltrolysis. Go!
Stan Meyer's helper technician Chambers fled to Canada and started his own company called Xogen and filed Patent for his version , since he knew about previous work. The small unit written up as construction manual was called HYDROSTAR. He had purposely left out the pertinent details about the coil flyback high volts generated in both Patent and the released manual.I have the original paper printed manual.  Ebay sells disc for this, but no details on high volts. Most Patents don't divulge exact every small detail required , except for the Horvath Patents.
Others have requested, in the past, on how the original Hydrostar Hydrogen Generator had the pulses divided down to get 20Htz from 20,000 htz main oscillator.  That was for going to the toroid coil for magnetic field pulses into the rising ions of solution. The IC CD4059AE can be used for that, as well as a divider for 1000 cycles down to 1 per second, for a flashing LED, so as verification that the main oscillator is in working state for your other circuits. Ic available on Internet Ebay. The full manual is available on disc. The ferrite toroid core wire coil is too much trouble to make, but can be purchased completed, or a 2 piece ferrite UU core set could be used, so as getting a closed flux core, and WAY easier wire winding. The Hydrostar circuit was an offshute of the Meyer resonance cell by Chambers . He used to work as tech engineer for Meyer in Ohio. He fled to Canada and filed Patent for HIS version of the circuit. The Patent omits notation of flyback coil high voltage connected to the Main electrode pipes water capacitance cell. He says the magnetic field circuit increases energy content of fuel gases emitted, by spinning the ions in different direction. Hydrostar was purposely then JUST A MODIFIED circuit to only increase car gasoline mileage by introducing Hydrogen and oxygen for about 25% increase in gas mileage.
The divider IC circuit itself does work. I use it to verify my Dr. Clark Zapper has the oscillator working as led flash per second from 1000 cycles.
« Last Edit: August 28, 2024, 02:15:46 am by russrHHO »
