Author Topic: My new approach  (Read 177467 times)
0 Members and 4933 Guests are viewing this topic.
Re: My new approach
« Reply #456 on: May 18, 2024, 08:52:21 am »
Today I finished printing the parts but could not do much to assembly as  I still feel like shit
I printed two flanges
The coil former
5 wire direction wheels
Two cones for holding the bobins
And a small screw cover to center the axis on the other side
Re: My new approach
« Reply #457 on: May 19, 2024, 13:47:23 pm »
Today I feel much better… lost about 5kg of health this days
I’m about to put the automatic coil machine to work
Just hopping it will work as expected
I’m going to try making a video of the bifilar coil that is on the prototype
Re: My new approach
« Reply #458 on: May 20, 2024, 08:14:15 am »
good to hear!
Re: My new approach
« Reply #459 on: May 20, 2024, 13:12:06 pm »
Where video?
Re: My new approach
« Reply #460 on: May 21, 2024, 06:19:49 am »
Hey there, I didnt uploaded the video because was too long and didn’t show much
I decided to make another video in a live on YouTube so it’s recorded at once
In the tests I show the working of the resonance and try to detect some feedback
I use a 100nf capacitor that brings the resonance to 9khz with the 2.8mh bifilar
I will start the live tests in within 1 hour
If you want send live questions
« Last Edit: May 21, 2024, 15:34:25 pm by sebosfato »
Re: My new approach
« Reply #462 on: May 21, 2024, 08:43:30 am »
Hope you like the video
I was able to show that the feedback kind of indicate some frequency
Some tvs burned so the resistor was getting most the power at the end of the live
Probably after that smoking point
A better coupling of secondary with primary would make it work much better transferring power
Also like I said on video having Better wire diameter resistances would improve protection and transfer
Making it a non dissipative snubber may also be a better way to go because the capacitor is competing with the power that should going out
So I may give some improvements to hit harder
Re: My new approach
« Reply #463 on: May 21, 2024, 15:07:45 pm »
I got to conclude that having a low Q factor makes it harder to get resonance with some power in it
The high resistance ratio makes it hard to make it develop a current cause it would need to dissipate power
Hope the big coils I’m making have much higher reactance
What your ideas of that feedback signal popping ?
