Author Topic: Back to Basics  (Read 92022 times)
0 Members and 161 Guests are viewing this topic.
Re: Back to Basics
« Reply #152 on: November 15, 2024, 19:46:23 pm »
Kiss......
For years now, we try to keep it simple....Nothing worked sofar.
Anyway, Stan said that when the setup used 1 or 4 amps, that it isnt a big deal...
Re: Back to Basics
« Reply #153 on: November 15, 2024, 20:23:53 pm »
And yet so often the answer is just under our nose, and we don't see it.
Re: Back to Basics
« Reply #154 on: November 16, 2024, 04:10:56 am »
Who said anything about blocking current.
None other than Stan Meyers himself. He said many times ".... yada yada, Blocking diode..." and the diode is in every "circuit" diagram on the net.
This thread is titled "Back to Basics"
Did Stan Meyer show a circuit to anyone?    The answer is no, he did not
Re: Back to Basics
« Reply #155 on: November 16, 2024, 04:12:34 am »
Everything you have said is out of context.  I'm not gonna bother arguing with you any further.
Re: Back to Basics
« Reply #156 on: November 16, 2024, 11:53:18 am »
You speak in riddles.. :)
Have you figured it out how it works?
I am  curious about what you mean  :)
Re: Back to Basics
« Reply #157 on: November 16, 2024, 13:40:22 pm »
My recent work on adding magnetic field to the cell is clear on how resistance increase because when the ions are under magnetic field they are deflected! The hole point is having enough field and right configuration so the waves can grow and the cell work as a generator…
The higher the acoustic energy build the higher will be the voltage because lenz law
The cell must act as a resonant cavity but not are electromagnetic waves but for pressure waves
My theory tells that if we otherwise apply ultrasound directly and tune to this having an electrode the size of the peak of the movement of ions than you can have it to accumulate voltage and this voltage will act as a resistance reducing the current flow
I believe the chineesed videos I posted they may have used it
Re: Back to Basics
« Reply #158 on: November 16, 2024, 13:46:02 pm »
The stacked resonant cell had coils on it build in Vic so my best guess is that they probably worked in a Quadrature manner as to not only drive the waves but synchronized and amplify the waves along the tube
There’s a lot to do more but again I’m very positive that it can work at least theoretically
Ideally would be possible to achieve more efficiency with superconductor capacitors and coils
Re: Back to Basics
« Reply #159 on: November 17, 2024, 14:56:59 pm »
V=IR
If you want to measure 20kV across water, which has a low resistance to electric current before electrolysis occurs, what do you suppose the amp level needs to be?
Obviously it can't be zero, can it?  Otherwise voltage would be zero.
But it can't be high current either or you will have electrolysis instead of water splitting.
So how do you get high voltage with low resistance without getting high current?
KISS
