Author Topic: LapperL's Cell  (Read 10825 times)
Re: LapperL's Cell
« Reply #16 on: May 29, 2008, 18:14:00 pm »
Spike,
I'm having a blast!  I love this stuff ;D
I did wire the cell in a series of three and ran some tests.  The cell definetley did not heat up.  I did notice that the voltage at the cell increased.  When pulsing 5 vlts to the rotor I was getting 22 volts at the cell.  Unfortunetly none of the local autoparts stores have any amp gauges in stock so I still don't know how many amps I'm putting into it. Looks like I will have to order it off of the internet.  I hate waiting of shipping!!!.
When I increase the voltage at the rotor to 8 volts, the cell voltage went up to 36 volts.  At 10 volts to the rotor the cell voltage rose to 42 volts.  Regrettably  my gas production was not even half of what is was when it was wired parallel.
So, I changed the wiring back and proceeded to run some test to see how hot the cell would get.  I ran it for over a half an hour (until my water pump drained my little 12 volt battery) and was consistently evacuating the water out of an inverted Dasani 500ml water bottle in 43 seconds.  In the beginning it took 46 seconds but once the cell warmed up (approx. 10 to 15 min) it dropped to 43 seconds.  The water and cell got hot but I could still touch it.  I need a temp probe also.
I stopped my stop watch once the first bubble escaped the unaltered water bottle.  I need to check and see how much volume the water bottle hold when it is completely full to the top.  I'm assuming that it is slightly more than 500 ml.  If anyone knows off hand I would appreciate the info.
I'll perform some more tests tonight.  Hopefully I can find an amp gauge by then.  Temperature probe also.
Until next time,
LapperL
  • OO-Rah!
Re: LapperL's Cell
« Reply #17 on: May 29, 2008, 23:56:23 pm »
Now Your Hooked,  ;D
Spike
Fiditti
Re: LapperL's Cell
« Reply #18 on: July 15, 2008, 21:09:44 pm »
Spike,
Would you explain the difference between running the cells in parralel and/or in series?  I'm new to electronics.  Thanks.
Re: LapperL's Cell
« Reply #19 on: July 15, 2008, 23:15:37 pm »
Fiditti,
  Here is how Spike got the point across to me.
Think of a plate cell, How they only     run  with a positive plate in the middle, and two negative plates on the end. All the plates in between are neutral plates, That produce gas by sharing electrical fields with the ones next to them. Neutral plates generate a positive and negative field, Look up a smack booster pdf, He has a good illustration were he explains voltage drops.
http://smacksboosters.110mb.com/Smack.pdf
I think it should clear things up.  It did for me.
LapperL
  • OO-Rah!
Re: LapperL's Cell
« Reply #20 on: July 15, 2008, 23:23:14 pm »
Thanks LapperL
I appreciate it.
BTW anything new on your project,
Or is summer time or work keeping you busy.
Spike
Re: LapperL's Cell
« Reply #21 on: July 15, 2008, 23:43:04 pm »
Work has been kicking my  ASS!!!!  Summer time is a real busy time for us, so I have not had too much time to experiment. I have been playing with the torch and trying to get the cell to circulate without a pump.  Nothing to speak of really.
One thing that I can comment on in regards to the circulation pump, is that they do not hold up in the long run.  They are not made for hot water and most of them are designed for intermittent use.  If we find that they are still necessary, then unfortunately, an actual hot water circulation pump (1 to 4 gpm) run anywhere from $200.00 to $400.00.  OUCH!!!!
I really like the looks of your new design.  Any ideas on how to shrink it in order to use on your vehicle?
LapperL
  • OO-Rah!
Re: LapperL's Cell
« Reply #22 on: July 16, 2008, 00:19:46 am »
LapperL
I've been working on ideas, On making it smaller.  ???
I think I got it. ;)  But it will have to wait.
My next few weeks are going to be pretty busy.
Spike
