Author Topic: Frequency generator with 3 squarewaves / 3 primairy coils / 1 secondairy coil  (Read 16188 times)
Outlaw,
I talked to dynodon about the connections on the coil of Meyers they saw.  He said it had the 4 contacts coming out of both sides like the side we can see in the photo.  8 contacts total he said he was sure.  Thats 4 ea for the chokes, 2 for the primary, and 2 for the secondary.  I think thats how it should work.
BUT ON PAGE 8-7 OF THE TECH BRIEF
VIC Voltage Sync-Pulse Circuit
Voltage Sync-Pulse Gated Frequency (583 / 602a xxx 583 / 602n) (603/604a xxx 603/604n)
of Figure (8-1) as to (605/606a xxx 605/606n) (607/608a xxx 6071608n) (609 / 611a xxx 609 /
611n) of Figure (8-2) ... all, forming Voltage Pulse Burst Wave (619) as to Unipolar Pulse-Train
(780A), Crossover Unipolar Pulse-Train (780B), and Clipped Unipolar Pulse Train (780C) as to
Traveling Voltage Wave-Action (770) of Figure (8-1) of opposite voltage polarity
RE: Voltage Wave-Guide Memo WFC 427
Stanley A. Meyer 8-7
(+/-) of equal Voltage-Pulse Amplitudes (+Vpp/- Vpp) are zero reference to electrical ground state
(OV) by placing Amp Inhibitor Circuit (860) (Amp Inhibiting Coil 617, Blocking Diode 618, and
Magnetic Induction Core 619) between electrical ground (OV) and Center Tap of Dual Bifilar
Secondary Pickup Coils
  (616A/B) of VIC Matrix Circuit (690) of Figure (7-8) as to VIC Impedance
Network Circuit (620) of Figure (7-1) , as illustrated in (840) of Figure (8-10). By doing so, Balance
Phasing of opposite voltage intensity (+Vpp / - Vpp) is accomplished without experiencing current
influxing caused by differential variances where Negative Voltage Peak Potential (-Vpp) is less than
Positive Voltage Peak Potential (+Vpp) or Vise Versa ... allowing Inductor Resonant Choke Coils
Electromagnetic Fields Intensity (+Z2 / -Z3) to be, in turn, free of Electromagnetic variances of
intensity (Z2 - Z3). This non-voltage shift (Balance Phasing of opposite Voltage Potential) helps
prevents atom displacement during "Snapping-Action" by which "Resonant Electrical Stress" of
opposite electrical polarity (RU/RU' - ST/ST') is applied equally across Water Molecule (s) (85) to
propagate either Static (585) or Dynamic (612) Electrical Charging Effect (s) at elevated Voltage
Peak Potential (s). Amp Inhibiting Coil-Assembly (617) is made up of magnetic inductance
Stainless Steel 430FIFR wire material wrapped around a closed-loop Induction Magnetic Core (619)
which is a separate coil-unit (860) apart from VIC Coil Assembly (580) of Figure (6-1). Blocking
Diode (618) functions as an "Electrical Isolator" that prevents electrical discharge of Dual
Secondary Coil (616A / B) during applied Pulsing Operations (49a xxx 49n).
To ensure and maintain Capacitance Charging Effect (650) of Figure (7-4) across
very true john
 but to not see the internal of the 3 d object cant give you all the answers. .. just throwing out posibilities... theres one thing i would say is kinda over looked.. the secondarys are already external..  they are gonna be sodered to choke tab anyways right? if it was a full bobbin there wouldnt be a spot for the last winds tab since its already external. so maybe it is 4 primary and 4 chokes.  was the one dynodon seen wound?
cheers
outlawstc
komtek has a coil built and on a circuit.  He says we have to have another signal that hits at 90 degrees.  He thinks its a RF or micro freq that has to be added.  Bob Boyce said his hydroxy production went extremely high when a diode in his alternator failed and ran one leg of AC with his circuit.  We may have to add another primary for a seperate signal to get performance.
this is how i see 6-1 in sync pulse configuration. not saying its right, just throwing paint on the canvas.
i think having the primary magnetic field permeate into the secondary nad the resonant ss chokes is all we need.....one primary....stan never mentions 2 primaries in his solid state setup using dc pulses......remember there are 2 different attack methods rotary and solid state...
but what are the impeadance effects if it were like this.???.  those duals primarys would be 180 out from each other wound like that right?  them being 180 out from each others current path on the induction core crossing in the middle stepping up to next level of wind.. notice how it would give you a positive inner wind and a neg outter.. maybe this puts off a different type of induction field with the core.?? what determines polarity within a single wound wire? direction of current flow right?
The full size pictures and files for Banki's 3 freq generator can be found in this thread:
http://waterfuelforall.com/forum/index.php?topic=6.0
Note that you have to be a registered member of the forum in order to see and download any of the attachments.
hope this helps
