Author Topic: Stanley A Meyer Multi-Tier Mag Gas Plasma Generator  (Read 2712 times)
Re: Stanley Meyer Multi-Tier Mag Gas Plasma Generator
« Reply #8 on: October 03, 2018, 23:30:53 pm »
Has grindle see some results, Jim?
Ill gues that he must have seen something that makes him going...
Can you invite him here?
cheers
« Reply #9 on: October 04, 2018, 02:36:21 am »
hey grindle  checkout this articleAn early un-classified report that validates  NASA interest in the magnetic gas lattice concepts mentioned in
SM89**  transcript CoAr FeAr and NiAr exist
REFTitle:
   Theoretical study of metal noble-gas positive ions
Authors:
   Bauschlicher, Charles W., Jr.; Partridge, Harry; Langhoff, Stephen R.
Affiliation:
   AA(NASA, Ames Research Center, Moffett Field, CA), AB(NASA, Ames Research Center, Moffett Field, CA), AC(NASA, Ames Research Center, Moffett Field, CA)
Publication:
   Journal of Chemical Physics (ISSN 0021-9606), vol. 91, Oct. 15, 1989, p. 4733-4737. (JChPh Homepage)
Publication Date:
   10/1989
Category:
   Atomic and Molecular Physics
Origin:
   STI
NASA/STI Keywords:
   CATIONS, ELECTRON STATES, GROUND STATE, RARE GASES, SPECTRUM ANALYSIS, TRANSITION METALS, ARGON, COBALT COMPOUNDS, COPPER COMPOUNDS, HELIUM, IRON COMPOUNDS, KRYPTON, SELF CONSISTENT FIELDS, WAVE FUNCTIONS
DOI:
   10.1063/1.456762
Bibliographic Code:
   1989JChPh..91.4733B
Abstract
Theoretical calculations have been performed to determine the spectroscopic constant for the ground and selected low-lying electronic states of the transition-metal noble-gas ions Var(+), FeAr(+), CoAr(+), CuHe(+), CuAr(+), and CuKr(+). Analogous calculations have been performed for the ground states of the alkali noble-gas ions LiAr(+), LiKr(+), NaAr(+), and KAr(+) and the alkaline-earth noble-gas ion MgAr(+) to contrast the difference in binding energies between the simple and transition-metal noble-gas ions. The binding energies increase with increasing polarizability of the noble-gas ions, as expected for a charge-[[/iinduced dipole bonding mechanism. It is found that the spectroscopic constants of the X 1Sigma(+) states of the alkali noble-gas ions are well described at the self-consistent field level. In contrast, the binding energies of the transition-metal noble-gas ions are substantially increased by electron correlation..............
http://technologygateway.nasa.gov/media/CC/lenr/lenr.html
perhaps you've seen the video with Stan entering the Lewis NASA lab in Cleveland. which did a lot of
work on propulsion systems Think about satellites requiring a lot of power....
coincidentally about the same timeframe  as article was being published
« Last Edit: October 12, 2018, 10:54:29 am by jim miller »
« Reply #10 on: October 04, 2018, 06:40:59 am »
like the design so far, I'll think I'll build one too! instead of your cross braces, I'll see if a Plexiglas or Lexan donut shaped disc with holes drilled for the 4 vertical all-thread  support rods.
Plexiglas (r) is the US trade name for Perspex, as you call it across the pond...I think I'll make two   one fro the top spiral level and another to be halfway between the 3rd  and 4th spiral rings...
I'll order the same type of copper tubing   because it's  available locally..
« Last Edit: October 12, 2018, 10:55:43 am by jim miller »
« Reply #11 on: October 07, 2018, 18:23:16 pm »
« Reply #12 on: October 07, 2018, 18:30:21 pm »
"Mag Gas 6 Tier System in temporary soldering jig
"Theoretically
Once the vertical flow and return tubes are  soldered in, then the pump  and windings are then normally added
After pressure and leak testing, then tube pickup windings are attached to the transfer box for power control for  house
The pulse electronics would then be added and tested
The magnetic slurry or gas is then added
A small motorcycle or automobile battery is used to start the pump initially and  after a short
interval an small amount of current is used to recharge the battery"
 hey g thanks for sharing---why don't you join the forum?
regards
« Last Edit: October 07, 2018, 19:10:56 pm by jim miller »
« Reply #13 on: October 07, 2018, 20:54:51 pm »
That looks good!
« Reply #14 on: October 11, 2018, 20:27:08 pm »
thanks to anoni mouse for this image,  it's another part of the puzzle
« Last Edit: October 11, 2018, 20:44:38 pm by jim miller »
« Reply #15 on: October 11, 2018, 20:46:22 pm »
it looks a lot like one of the pumps in one of the earlier epgs  12 or 13 fins
