Author Topic: S1R9A9M9 18HP Briggs riding mower engine ran on water( 2008)  (Read 2107 times)
Login to see usernames and 10 Guests are viewing this topic.
Re: S1R9A9M9 18HP Briggs riding mower engine ran on water( 2008)
« Reply #8 on: Yesterday at 23:03:38 »
Battery runs starter. battery removed. Starter terminal has extra wire to conversion circuit. Engine starts using 12v from battery . After idle speed , the dual alternators with rectifications operate 2-3 circuits with amps . !2 magnets run alternators. Water in carb changes to water vapor pressure at minus 34% timing. Minor Hydrogen from spark plug electrolysis. Ignition volts increased with Capacitor70 circuit with pulsed step up transformer. S1R9A9M9 electromagnet special wound applies the late timing and magnetic field for plug tips. The water vapor expands quickly with piston pressure from same polarity ions repulsion. Shop technicians inventors harassed. Briggs 18HP self running mower engine ran on water summer 2008. The earlier several car conversions used small hydrogen from spark plug electrolysis. Double spark gaps required with inductor and diodes in vacuum chamber to release Radiant Energy for further efficiency, when high V hits cathode..
