8XA IS NOT RESONANT CIRCUIT!
This was the first patents from Stanley Meyer before the resonant system.
Dont try to achieve resonance with this because you will get frustrated.
This shows the true difference from all of you and me as I learned something for I got resonance with the 8xa circuit but more than that I made sense of the words by way of experimentation using the scientific method which is something none of you ever try and make use of.
Like any tool it is only as good as the person making use of it and since it is clear to me that most if not all of you never bothered to even pick up the tool known as the scientific method you've been totally stuck in trying to figure out this technology. You all get mad at me for showing an understanding of this technology but never take the time to attempt to understand anything that I say. I can't even count just how many times I have pointed everyone in the right direction to only be told to go away as we don't want what it is you are showing us. I have spoken of the New Zealand video many times in the past and even took the time to post the video for you all to look over.
The 8xa circuit is of Meyer's early work and from there one can gain an understanding of this technology. Did you know that you can re-wire it to be just like a VIC transformer? Nope because you are too busy running your mouths and typing away on your keyboards to ever get to performing any real world experiments. Your all so afraid of failing that you never start doing anything. Or you are so strapped for cash that you can't afford to build anything. Either way if you don't get some experiments under your belt you will never learn anything. This is the primary reason why when I speak of how this technology actually works you have no idea what I am talking about for you have no practical experience with this technology as you are just working with theories in the mind.
The voltage intensifier circuit was the hardest part of this technology to figure out and I went through more than 20 transformers before I got the hang of it and was able to start seeing just what it is actually doing. I have a lot of experience in building these transformers now having made and tested all types of different cores. I made VIC's with I, C, E, and the donut cores, wired these things up all types of ways. But I took notes as using the scientific method requires the use of a laboratory note book. I learned by doing as sitting on one's behind doesn't give any real world experiences with this technology only hands on boots on the ground work does.
Example, in the photo I just posted of the 8xa circuit you will see the words, "Increased coil length equally increases applied voltage level/amp restriction since induction/capacitance increases proportionally." Did any of you give these words a try and observe the results? More than likely the answer is no, right? as you are too cheap to build more than one coil size and test it in a manor that would give you a chance to see what these words are talking about. So to all of you these are just words that have no real meaning but for me I learned the meaning behind the words as there was a lesson to be learn here. The 8xa circuit is an easy circuit to make but it's old Meyer tech and since it has no dollar value you can make right now you don't waste your time with it. I took the time to learn this technology from the ground up through the foot steps of Meyer as he learned this technology. Sure I had to spend some money on something I could never sell but the lessons that needed to be learned from this sure was worth it. I think I made and tested at least 10 different size choke coils and from this I learned. When I felt I was ready to move back to the voltage intensifier circuits I did so and made all the progress I have shown you in figuring out how to get the high voltage to the load and not have it be trapped at the secondary coil. So when you see me post waveform shots like this know it took a long time to figure out how to get the high voltage to the load.
(http://i1025.photobucket.com/albums/y320/h2opower/personalpics009_zpscf31888c.jpg)As these results didn't come easy as it took a lot of hard work dealing with older Meyer technology to be able to get this far. But the Nay Sayers told you these results are a dime a dozen but I have yet to see a single person show results like this. Then I get the question, "where is the gas production?" and when I answer it to the best of my abilities to do so the answer I give is rejected. But now it seems common knowledge that you need 1kv or more per resonant cavity to get this technology up and running correctly, hum... I wonder where that came from?
I have come to the conclusion that what you all really want is for someone to help you start a business with this technology. I just observe all of the competition going on and came to this conclusion. You aren't wiling to work for it and some have even rejected it when it was freely given to them.
This year is going to prove interesting as I have a lot planned for this year and if all works as planned it will be a year to remember.
