Author Topic: mechanical analogies  (Read 14386 times)
0 Members and 14 Guests are viewing this topic.
Re: mechanical analogies
« Reply #24 on: November 16, 2016, 17:31:23 pm »
at resonance a very big amount of energy get accumulated but is potential form if you discharge it its consumed... at resonance the voltage developed is related by the current by ohms law but with reactance,.. thats why its called reactive energy... its said it cannot be used..
« Reply #25 on: November 16, 2016, 19:01:21 pm »
Matt over there is starting to show some effects with current,you have to log in to see them.
http://open-source-energy.org/?PHPSESSID=n1mvp8pd4074jqs84cf5sbfdo2;topic=2785.725
« Reply #26 on: November 16, 2016, 23:37:44 pm »
I didn't see much just a couple of scope shots
« Reply #27 on: November 17, 2016, 03:36:39 am »
yes he's the first ive seen post voltage and current shots, Im looking forward to seeing it at resonance...the current waveform.
« Reply #28 on: November 18, 2016, 01:05:45 am »
Today I hope to finally do some tests of my theory if I get some information interesting waveform I will post to explain the way things are being addressed.
« Reply #29 on: November 18, 2016, 11:47:33 am »
This is a system approach taking the chokes to work as their definition to choke The AC current  from the DC line
When the high voltage is applied the electrons are momentarily Took away from the atoms at either electrodes turning off the covalent bound because without electrons share there is no bound
The electrons must be returned to the atoms to stabilize and form the gas
« Last Edit: November 18, 2016, 19:16:51 pm by sebosfato »
« Reply #30 on: November 18, 2016, 19:59:02 pm »
Check the gas production of this guy!!!!!!!!!!! https://m.youtube.com/watch?v=Kk0xRSlcA5M
« Reply #31 on: November 19, 2016, 01:02:32 am »
I did some tests today but um not happy with the cell electrical connection it Keep failing....
