Author Topic: Salt Water  (Read 3790 times)
Re: Salt Water
« Reply #8 on: August 07, 2015, 00:20:47 am »
I've made two attempts in the past three days to build a static generator.  Both were defeated by defective components.  Rather than wait for new parts to come in the mail, I'm considering a third design.
Re: Salt Water
« Reply #9 on: August 07, 2015, 05:49:17 am »
you can create a van  de graph with cocacola can in you tube you find something ...
is not very hard..
i never tried.. i once tried to make the kelvin thunderstorm but got no results either... i didn't add salt to water, thought...
Re: Salt Water
« Reply #10 on: August 07, 2015, 07:16:40 am »
That's very close to what I'll try next.  But if I put my tube inside the can, it might make too much static and discharge right away.  I'm thinking to try a HV wire to the inside of the can, with a grounded ring below the can.  When the wire sparks to the ring, the charge on the wire above the ring will transfer to the can.  Maybe.
