Author Topic: The Right Question?  (Read 33894 times)
Re: The Right Question?
« Reply #136 on: February 02, 2016, 00:49:35 am »
You can buy an electrically powered ink pen which contains the necessary chemicals to plate platinum.  In fact, a variety of pens are available, for plating different metals.  I'm attaching the price list document, which I can't open since I don't have MS Office.  Maybe someone who does have this software can open the file, then post a screen shot?  If the price is right, this might help a lot of us.
« Reply #137 on: February 02, 2016, 02:43:32 am »
that would be wonderfull..didnt saw platinum on the list.. there were palladium and rhodium... i remember those pens, its good for jewlery...but the problem is that to cover a big area the pen wont work... my plates for example were 30cm in diameter... i was planing to make a 25um thickness layer,,,
i´m not sure if platinum would do any good.... this project aimed very low voltage high current... the goal was to have up to 9000 amps at few milivolts...
now i´m into pulsing the water with my big vic...
i´m constructing today a ambient air lazer.. hoping it will work..
« Last Edit: February 02, 2016, 03:38:14 am by sebosfato »
« Reply #138 on: February 02, 2016, 06:01:02 am »
would a process similar to anodizing be good for platinum ?
surely catalytic converters must be tin or steel with a very thin plating .
https://en.wikipedia.org/wiki/Anodizing
« Reply #139 on: February 02, 2016, 07:10:08 am »
no Massive... its a matrix of ceramic with the particles fine distributed on it..
http://citeseerx.ist.psu.edu/viewdoc/download?doi=10.1.1.464.4181&rep=rep1&type=pdf
http://www.finishing.com/427/46.shtml
http://www.materialstoday.com/metal-finishing/features/specialty-metals-platingpart-i/
some of the formulas i used can be found on this links but  i got them from books at the university..
i had to choose the simpler so i could have all the chemicals required..
if i had more 1000$ i could get a decent piece of platinum to plate and make tests with it... is something i´m interested into...
from my understanding the platinum in the solution as goes off to the cathode the platinum come off from the anode...
the solution was like 0.1ph... if i remember well for the palladium solution
