Author Topic: Restrict Amps with Source Voltage Amplitude  (Read 6637 times)
Re: Restrict Amps with Source Voltage Amplitude
« Reply #16 on: January 07, 2013, 00:34:58 am »
Did you build the power supply like the one I showed?
« Reply #17 on: January 07, 2013, 01:31:57 am »
If you're referring to the simple voltage control image, yes, that is what I built.  I am definitely getting some interesting results now using the voltage control module with the cell.
TS
« Reply #18 on: January 07, 2013, 01:34:10 am »
Awesome! Glad it works for you as it is a very important part of the system!
« Reply #19 on: January 07, 2013, 01:45:45 am »
Have you determined how or at what point to set the voltage control at related to the coil you are trying to charge?  In other words, the proper way to tweak it?
TS
« Reply #20 on: January 09, 2013, 04:31:34 am »
 ;D   I just got my coil and WFC vibrating at higher than 800kHz!!!
TS
« Reply #21 on: January 09, 2013, 12:13:04 pm »
TS
Wow what kind of pulsing gear do you have?
« Reply #22 on: January 09, 2013, 14:00:59 pm »
TS
Heh, just Tony's VIC circuit, slightly modified.  Was using a relatively small coil, all 5 wires at 1:1, bifilar.   Didn't do anything earth (water) shattering.  Made my TIP120 start to smoke.
TS
« Reply #23 on: January 12, 2013, 03:35:46 am »
I think ima bout to ask a silly question but I can not find any information as to the value of the variable inductor on the negative leg of the transformor.....is there specific info about that or does it really matter?
