Author Topic: The water coil  (Read 12984 times)
Re: The water coil
« Reply #40 on: March 28, 2014, 09:04:09 am »
can you measure the resistance with a dmm? I will try this idea of capacitor arrangement I told you once I get these stainless tubes...it seems like it's an LC resonance type of thing too. I need some heavy duty ultra fast ns diodes .. it's hard to find these locally.. anybody knows an online source?
« Last Edit: March 28, 2014, 12:46:08 pm by geon »
Re: The water coil
« Reply #41 on: March 29, 2014, 21:55:30 pm »
Hey Geon, i guess you might want to try find a local seller for electronics... there might be one near... when i lived in italy i use to buy things from RScomponents you should try to find some similar place...  good luck
I could not determine the resistance yet but is a damn good idea!
Re: The water coil
« Reply #42 on: March 29, 2014, 23:05:12 pm »
as far as conductance pure water shouldnt have any.. if you want to make water even more insulating add sugar.. salt will make it a little conducting, if you want to make it very conducting you can form a colloidal solution of metal nanoparticles.. but that's too much trouble to do in order to make hydrogen..
Re: The water coil
« Reply #43 on: March 30, 2014, 09:39:52 am »
anyone tried this?  you have to change the bifilar coil I made a mistake switch the ends...  ;D
« Last Edit: March 30, 2014, 14:47:21 pm by geon »
