Author Topic: Stan Meyer Documents from meyerarchive  (Read 11459 times)
Re: Stan Meyer Documents from meyerarchive
« Reply #24 on: December 15, 2013, 21:40:52 pm »
Well i have been on this forum for quite some time.. Its pretty bold just jumping into a convo and calling someone a fraud with little to no backing as to why you have concluded this.. I don't see anything fraudulent in Neal's video.. He is idling a motor on hho from water using a injector setup to time and inject hho into the intake... This is a much better approach for getting a motor to take in the fuel without flashback as well as for metering.. I could set up a high power hho system and most likely get a motor to run full power... This is not the goal though since I would be relying on a external power source to try and run a system that i would prefer to be its own power plant for productions allowing a closed loop system.. I have o reason to believe Neal is doing that in the video.. I think he is relying on a external power source... There is nothing wrong with that when your simply trying to observe just how much HHO is needed to run a motor.. From there you must figure out how to get the motor to be the power plant that can produce it with little energy.. Neal has made no claims of a closed loop system.. He just claims hes running on 100% water.. That is not a lie.. Great job Neal
« Last Edit: December 15, 2013, 21:56:57 pm by outlawstc »
« Reply #25 on: December 15, 2013, 22:22:55 pm »
one reason I like this forum is that the owner of the thread can delete silly posts and keep the thread on topic :)
Thanks Kevin. This topic is in Jim's project section. That way he can decide what to do, just like all other projectsection owners in their own sections. 8)
Cheers!
« Reply #26 on: December 15, 2013, 22:32:16 pm »
I am a fraud ??
Would you care to elaborate please ?
Calling a business a fraud just may end you up in court !
But please do elaborate why I am a fraud !!    If this is the way the people on this forum behave
then i personally want no part of it, I bring you a video of something real and i am insulted
like this ? Geez I wonder why no one shares info.
My name is Neal Ward and i am hiding from no one.
Hi Neal,
The people on this forum is from my point of view, not the proper way of addressing all members who are just reading and learning/lurking.
Would you like to show us here how you did ran your engine?
It reminds me to my project of running the yamaha motorbike on HHO only.
See my projectsection, which i shared.
« Reply #27 on: December 15, 2013, 23:37:23 pm »
The words of  the poet Khalil Gibran might be instructive ,roughly translated from  Arabic:
"The spoken word once uttered ,nor all tears piety can wash away."
It is even more so in this age of arkiving by the Never Say Anything crowd ;)
« Last Edit: December 16, 2013, 02:42:37 am by jim miller »
hydrofuelincanada
« Reply #28 on: December 16, 2013, 03:08:07 am »
Thank you ! And you are right , this was to prove the ngine will run properly, next step is to figure out how to increase the rpm, then self power....
« Reply #29 on: December 16, 2013, 05:48:27 am »
George,
I can see in the video everything worth knowing.. Hes running a big plate cell into a bubbler then though a  clear hose into a injector manifold that has 4 injectors... He has a circuit next to the injector for controlling the switching of them.. This is all stuff that can clearly be seen in the video! He also shows that he has removed the fuel pump relay! and also others! Obviously you are not experienced and or observant enough to extrapolate the info you desire! Not his fault! I bet he would of been happy to answer any questions if you didnt label him a fraud then expect him to give a further response without you asking him kindly..  I just dont understand some people today :-\
« Reply #30 on: December 16, 2013, 06:40:06 am »
George,
If he is not using a "non-combustible gas" recycling tube to match the burn rate of regular fuel for his given engine,  it will never run for long or under any stable control....
See Meyer's manuals....must have to match fuel burn rates and temps.
Cheers,
jp
« Reply #31 on: December 16, 2013, 06:51:48 am »
Well they are his to do with what he wishes......But you don't think Mankind may need this a little bit more than he needs a dollar.
Look where Hoarding got Stan Meyer, Put it in the public's hands and no one can stop it.
My opinion.
Neal Ward
You don't know a thing about Meyer, Me, or the patent process.
Patenting processes and systems can be easily blocked in it's infancy.
Meyer got his ideas from others as it seems so have you.
Why do you think Meyer's technology will be so good for mankind.....it hasn't done too well with everything else with which we've been blessed.
Peace,
jp
