Author Topic: Now offering Electron Extraction coating services  (Read 8056 times)
Re: Now offering Electron Extraction coating services
« Reply #8 on: July 23, 2013, 05:12:53 am »
They havent cut youtube or facebook yet knock on wood... But I cannot access the mfg of the spray gun either not sure of where else I cant go yet. But seems to be getting more limited everyday.  :'(
« Reply #9 on: July 23, 2013, 09:27:18 am »
ok strange stuff did you do sumthin Steve to fix it or did the system just decide to let me back on either way I'm back. I'm having serious issues on my end with every type of electronic device I own...
« Reply #10 on: July 23, 2013, 17:55:37 pm »
i am just on holiday... 8)
« Reply #11 on: July 24, 2013, 21:28:23 pm »
I am must say that the forum has some automatic maintenance programs running, which run some jobs to clean databases etc.
These jobs come with the forum softeware and not made up by me.
I have opend a threat in the general section of the forum for forum issues.
Please follow the guidelines and i am more then happy to solve issues, where possible.
« Reply #12 on: July 24, 2013, 23:20:01 pm »
Hello fastimports3 ,i'v seen people get resonance with normal stainless T04.How this coating would help?prevent electrons,i understand...but if we canot get the voltage up is no use.I'v seen your video with distiled water.Distiled water itself restricts amps because it has no impurities,and alows some voltage.If this coating can restrict amps,use tap water and rectified wall power and see if it trips a fuse because of the amps.If not then the posibilities are endless...Please explain simple and skematic the purpose of this coating.Thanks for sharing!
« Reply #13 on: July 25, 2013, 07:25:36 am »
well since dielectrics decrease voltage maybe a semiconductor will increase voltage.. who knows :-\
« Reply #14 on: December 13, 2020, 00:52:22 am »
The coatings in this case are not for the fuel cell itself. They are for the electron extraction circuit of Stanley's. This unit gets placed on the output of the fogging device between the engine and is used for further destabilizing the water molecule. You are NOT trying to create hydrogen and oxygen. You are electrically charging the water molecule to create an isomer or another form of water with a different net electrical charge. The fogger begins or stages this process. To see evidence of this watch the following video. You can see the change in flame from boiling steam to cold fog. Many have debated the cold fog is lowering the flame temp and that is why you see an orange flame instead of blue propane flame. So I did tis experiment to showthere is a difference in flame properties when you subject the flame to the two different methods of produces atomized water vapor.
« Reply #15 on: December 13, 2020, 01:24:44 am »
Geon this is correct and why the ultrasonic devices in the cold fogger behave they way they do. The transducer is an actual semiconductor itself which restricts amp flow, it expands and contracts quickly sending shockwaves which disturb the molecular bond of the water. Stanley's drawings I believe are a mechanical representation of the circuit not the actual circuit. A piezoelectric schematic looks Stan's water fuel cell. And when coating some of the fuel cell parts with various metal oxides and placing them in water I have had the cell respond as if there was a diode in line with the cell as Stan's drawings suggest. I have a pdf from Morgan Electro Ceramics showing similar drawings and wave forms for they same parts used in the fogger devices and comparable to San's original writings for the fuel cell. This has lead me to start working on the light tunnel Stan referred to as the electron extraction circuit. And that is the main focus of this thread. I'm looking to create a device that the fog travels through and using LEDS in the visible spectrum UV and Infrared to assist photocatalyst in trapping some off the electrons flowing passed the neg and pos coated plates which them in their self create an output voltage to be consumed and change the electrical charge on the water thereby destabilizing it into fuel. I will try to locate the Morgan pdf and post it here for yo to see. Maybe it is in the other thread. I'll have to look.
« Last Edit: December 13, 2020, 02:38:28 am by fastimports3 »
