Author Topic: The VIC AND ALTERNATOR VIC  (Read 8577 times)
Re: The VIC AND ALTERNATOR VIC
« Reply #8 on: March 28, 2013, 03:38:50 am »
I mean all the energy of the circuit is applied acrooss the switch and load at the boost converter, the store current into the coil will be discharged thru a diode into a capacitor, thereto the switch has across drain and source, the the voltage from the battery sum with the inductor voltage...
In the case of the drawing i made the potential decrease at that point at the same rate that it increase so it would remain 0 if wasn~t for the battery potential;;;
when greater than 50% duty cycle is used more energy is acumulated assuming the discharge occurrs quick enough i guess the solution is going multi phase...
« Reply #9 on: March 28, 2013, 04:18:07 am »
You might be asking yourself if you did not tried this before, and if does why it did not work...
I tried this configuration some times with more or less power, but i was not able or was not clear the teory at the time to know exactly how much energy was going on there and how to apply it in the most affordable manner...
I guess is right about finding the frequency and power applied to get into on demand gas production...
I mean if the only way to get into that is to really apply more than 1500v acros the cell ...
Stan said it could be that simple that some one could build it from scratch at home with things commonly found like copper wire.. .
iron and ss all around
water abundant coming from the sky
« Reply #10 on: March 28, 2013, 09:00:21 am »
I remember Stan saying that..
But hundreds of people didnt find out what he ment....
I did last week a test with dc and hv.
Nothing special to report.
Hope you see some improvement with your boost setup.
« Reply #11 on: March 28, 2013, 10:17:43 am »
i found many drawings like mine googling boost converter coupled coils
Its a step up boost, and can be resonant operated with voltage multipliers, many possibilities
just increadible...
What keep me interested is that now i see that meyer was actually talking about well known circuit operations... thats why it was so clear to him...
Hope you find some results too
Thanks
Br
« Reply #12 on: March 28, 2013, 12:34:21 pm »
Why so many read and dont post?
http://en.wikipedia.org/wiki/Electron_avalanche
http://en.wikipedia.org/wiki/Dielectric_strength
My guess is that if the electric field is high enough than the bubbles just forming will see an electric field much greater since their dielectric values are close to one i guess... thereto the avalanche get sustained maybe 10 fold or more is not that hard to get
I guess the water should be pure as possible but some charge carriers may be neccessary to initiate the process who knows?
« Last Edit: March 28, 2013, 13:08:21 pm by sebosfato »
« Reply #13 on: March 28, 2013, 16:05:29 pm »
I noticed a increase in production if the pulsing is going, i don-t know theh energy efficiency yet although...c
Only up to 20 volts with city water, full of chlorine...
its indeed doubling th input voltage or so.;..
« Reply #14 on: March 28, 2013, 16:07:07 pm »
i think is the first time something really works at all, since is the first that i produce more gas than standart batery - cell straight connection...
« Reply #15 on: March 29, 2013, 03:48:41 am »
"The polarizability is an atomic property, but the dielectric constant will depend on the manner in which the atoms are assembled to form a crystal. For a non-spherical atom, will be a tensor.[9] "
Dielectrophoresis
