Author Topic: Update. Water Is A Fuel!!!!!  (Read 11285 times)
Re: Update. Water Is A Fuel!!!!!
« Reply #16 on: March 13, 2013, 02:32:10 am »
Hydrocars
Pyrolysis of water is termical process of decomposition water to hydrogen and oxygen gas ( flammable gas ) at high temperature. My english is limited.
What is percentage of hydroxy gas to steam to trigger flash point of water ( 212 F ) and what presure?
Thank for your ansver
andy
I really like that term " water smoke" and the enthusiasm Coats   :)  my interests are that of the "water smoke" but  when its under water .... the cloud that forms in the cells.... thats my "water smoke" :)
11 %
« Reply #17 on: March 13, 2013, 18:44:06 pm »
Thanks guys, just wanted to share my 2 cents and not sit around keeping all these wonders in my head wondering if im the only one that see's it this way, atleast others can put their opinions on it now that I shared and maybe something good may come out of it. I'm still interested in resonating the water molecule too, I think theres many ways of unlocking this fuel not just 1. But, I am unsure if stan did any magic, Even though I do think it can and will be done one day, I dont think stans car ran on free energy, I think he seen something in that solar silo when he was heating the water, he was trying to heat peoples homes. Wuts up with stans wfc Heater that sits in peoples homes? That ideal i can assure you came from that silo. He just completely stopped on that silo and whent directly to the lawn mower. Charles the guy I interviewed on youtube said he heard snaps, crackles and pops in stans fuel cell. Thats how oil sounds when its heated, Im banking on stan had the water so hot it was poping and steam was coming with the hydroxy and thats what ran the mower, the combustible water gas.
« Reply #18 on: March 19, 2013, 21:27:13 pm »
In the following video at 22 seconds you can see me light the (water gas.) The video is about 2 years old. You can observe hydroxy and steam mixing together to create a flash point of water, A Synthetic water gas! This is the fuel of the future!!! I have reason to believe this is what stan ran his mower on!
https://www.youtube.com/watch?v=kkqp3RTy4rM
« Reply #19 on: March 20, 2013, 13:05:42 pm »
Hi Hydrocars,
Impressive stuff! I think you have found something to investigate into.
I would like to start testing with this approach, what are your recommendation for this? Are the schematics in this youtube movie (which are hard to read) the ones you use?
Thanks for the input
Waterfuel
« Reply #20 on: March 20, 2013, 20:03:55 pm »
No, those schematics doesn't contribute to the production of hydrogen. I recommend getting a good hydrogen output clean of caustic soda, lye or hydroxide solutions and mix the hydroxy with water gas obtained after its boiling point to produce a combustible synthetic fuel. I'm sure additives would work but I dont recommend it.
Also, converting 120 to DC directly is ideal for such productions assuming the fuel cell is built for just that. I have about 60 plates all 6"X6" 1 to 1.5mm gap is ideal for a rough design. Some higher skilled gurus may just mix hydrogen directly to the mix, assuming they are safe about it, @ stevie.
Please dont forget to post your results if you decide to do this.
« Reply #21 on: March 20, 2013, 22:11:01 pm »
It is possible stans heads was Flycut making the engine a hybrid between a gas and diesel, with higher compression.
« Reply #22 on: March 20, 2013, 23:56:04 pm »
I've been thinking, I think that you can introduce superheated water into the combustion cylinder, and under the compression stroke I think the superheated water will further heat to its smoke point and all liquid under this pressure will hit the temperature that causes the water to gas conversion, I dont think you need hydrogen at all to run an engine on water using this method I think you just need to get your temperature right, and you might tweak the compression for better results. Just my thought.
« Reply #23 on: March 21, 2013, 02:24:20 am »
This may be viable to a very low proportion only since water vaporizing temperature increase with pressure up to a limit where it no longer can remain liquid. Of course this are hundreds of bars and hundreds of ÂșC and you need heat for getting into this...
The Nuclear reactors work on this basis so as the old smokymary trains...
Although i never had the ability to calculate that precisely. Its still a good idea for me. The thing is that it could only re-use the heat loss, thereto improving efficiency, but when you get to the point where your gain in eficiency is not greater than the effort to achieve it, than you can determine what is doable and what is not.
For example you need 4 liters of water to run a car per hour, but having 25% thermo mechanic efficiency, than if you used maybe 10 liters of water to achieve a 50% thermo mechanic efficiency you would be throwing away 6 liters of water to gain 25% so is not worth the effort.
regards
