Author Topic: Re: My Next VIC Design-Coulombs and Stuff  (Read 6249 times)
Re: Re: My Next VIC Design-Coulombs and Stuff
« Reply #8 on: March 05, 2013, 04:54:49 am »
I would say that resonance in this case instead of a propriety is one possibility, that allows dump even more energy into the system...
what happens if you put 5 amps into a capacitor for one second? well if its 1 faraday capacitor it would develop 5 volts in 1 seconds... assuming constant current...
constant 5 amps flow mean that in one second 5 coulombs of charge flows... 5 coulombs times 1 faraday = 5 volts or 12,5joules
the inductor is the same and oposite thing... if you apply 5 volts to a 1 henrie coil it will have 5 amps flowing after 1 second  = to 12,5 joules also
Its inverse properties
the capacitor steps up voltage for a current flowing
the coil step up current flow if voltage is applied
If you charge a coil and discharge into a capacitor it will discharge all its energy into the capacitor
isn't this how resonance work? one discharging fully into the other?
the fact that it step charges is not the meaning of resonance, but the effect of it, since it accumulates more energy than it can dissipate it apply a reversed voltage to the source (characteristic frequency and phase) so the source keep flowing more energy up to the point where its voltage sums to I*R thereto V= R*I  and Z=0  so Z=R
is that more clear now?
« Last Edit: March 05, 2013, 05:10:09 am by sebosfato »
« Reply #9 on: March 05, 2013, 05:10:35 am »
Some reading on the subject.
http://en.wikipedia.org/wiki/Coulomb
« Reply #10 on: March 05, 2013, 05:22:59 am »
exactly that!!!
Just to make it clear....
if you apply 5 volts to a 1 henrie coil you will get 5 amps flowing after one second. 5 volts times 5 amps * 1second equals 25 joules... by if you integrate over time, you get 12,5 joules since no amps were flowing initially!
look into the unities http://en.wikipedia.org/wiki/Farad
 http://en.wikipedia.org/wiki/Henry_(unit)
« Reply #11 on: March 06, 2013, 13:14:12 pm »
Very short and sharp pulses are the key to Meyers work. The radiant effects (see Tesla) achieved with these pulses unbalance the environment and add extra energy to the circuit (cold energy).
The shorter the pulses, higher will be the instantly energy.
When my oscilloscope return from the calibration lab, I'll post some pulse pictures so we can discuss.
« Reply #12 on: March 06, 2013, 19:04:48 pm »
stop calling it "cold energy" call it superluminous waves more appropriate and extravaganza..  ;)
« Reply #13 on: March 07, 2013, 08:46:06 am »
Looking forward to that.
« Reply #14 on: March 07, 2013, 21:27:33 pm »
i call it big bang... zero point energy tapper whatever...
i guess is just so great amount of power that it disturbs space and time stability... creating unexpected effects..
« Reply #15 on: March 08, 2013, 12:50:32 pm »
Yes, when you send an unidirectional pulse through a wire, you create both magnetic field and a radiant energy wave. The magnetic field maintains as long as you keep current flowing in the wire. The radiant wave only happens once (that's why we need to pulse it). This wave radiates out horizontally from the wire in all directions in form of a "shock wave". When you disturb the ZPE field, the field tends to move back to equilibrium, and when it does, cause extra energy to flow in the circuit.
(http://img534.imageshack.us/img534/3245/82171433.jpg)
In my opinion, the WFC has 2 ways to tap this kind of energy:
The first way is the way described above, with the sharp and short pulses.
The second way is the way that Meyer states in his videos: When you flex the atom of the water molecule, making the electron orbit elliptical instead of circular, the nature has to put energy in the atom (and this energy comes from the ZPE field too) to try to stabilize it (make the electron orbit circular again).
In many Tesla patents, he tap this energy with pulses through a spark gap, but for the WFC, a spark gap might be dangerous, because it can ignite the gases coming out.
(http://img694.imageshack.us/img694/4117/36044589.jpg)
