Author Topic: Amp restriction mechanism frequency doubling  (Read 43822 times)
Re: Amp restriction mechanism frequency doubling
« Reply #88 on: May 18, 2015, 12:10:59 pm »
Guys, limit your input current right at the source for starters.
http://www.ionizationx.com/index.php/topic,2962.0.html
« Reply #89 on: May 18, 2015, 14:11:48 pm »
Steve, this scope shot is from a russian guy. Power supply 8V @150mA. Pretty white hho cloud, 1 tube set, 2n3055 driver. Unfortunately I dont have the lpm, neither he did.
Timeshell, I went different with a LM338.
« Last Edit: May 18, 2015, 15:16:07 pm by uziao »
« Reply #90 on: May 19, 2015, 04:03:43 am »
Same idea.  I was basically saying don't saturate your primary with current.  You won't get the proper signals on the VIC coils of you are saturating the coils.
Right now I'm using an LM317.
« Last Edit: May 19, 2015, 14:26:54 pm by timeshell »
« Reply #91 on: May 29, 2015, 02:39:24 am »
i think i got the amp restriction! it became pretty noisy and the computer got crazy i seemed to be receiving ufo messages kkk
according to my theory due to the forces present the water act as a generator in series with the chokes when they collapse.. .the secondary receive this pulse and impede the current to enter the primary coil.
only at a certain voltage level this happening... unfortunately i burned all my transistors... and need to get more next month...
« Reply #92 on: May 29, 2015, 02:49:22 am »
In the end the idea to have the chokes on the same core as secondary and primary is good since it can be designed to have minimal or actually no amps going... to track specifically the resonance of that particular water...
than the system is tuned to that frequency.. of course to maximize resonance..
i'm afraid it become a self sustaining oscillation and won't stop generating just like stan said.. unless taking the water out of it..
maybe its a new way to even generate electrical energy guess what,, it all comes from the action chokes plus cell..
i believe don't you?
« Reply #93 on: May 29, 2015, 05:54:50 am »
Are you asking somebody in particular?
« Reply #94 on: May 29, 2015, 06:17:53 am »
Ts i'm the one who never believe, and never believed this applying high voltage across the gap with zero current... i'm just telling where i'm going..
perhaps i need to take my hat for some in the past that went blindly in that direction... i instead needed to understand but if you think about meyer was truly in his regards wanting us to follow his steps and bring it on.
i have this theory for few years now but only now i seem to see how to apply it...
i learned partially in physics 3
those concepts are key to understand whats going on.. but there is also the jump of the cat... when the molecules broke where the charge goes? and how it goes?
« Reply #95 on: May 29, 2015, 08:01:57 am »
The charge doesn't go anywhere.  It stays on the cell.
