Author Topic: Meyer's VIC Circuit PCB  (Read 11463 times)
Re: Meyer's VIC Circuit PC
« Reply #16 on: March 28, 2012, 13:02:23 pm »
A useful freeware archive unpacker utility (ie for .rar .zip) is jzip - choose the custom install to NOT install the searchbar......
i find jZip works well good alternative freeware to winzip etc
http://www.jzip.com/
7Zip is a good open source option without any built in spyware.
http://www.7-zip.org/
TS
« Last Edit: March 28, 2012, 15:36:11 pm by timeshell »
Re: Meyer's VIC Circuit PCB
« Reply #17 on: March 28, 2012, 14:14:06 pm »
I have a question about this schematic, Tony and others.. .
Why would you want a delayed signal getting into the Pll pin 3 which is the phase comparator input?
Being this way is understandable the damper resistor and diode in parallel with the primary...
Did you found any special reason for that?
I'm meaning pin 4 generates the positive so it turns off the first transistor pnp this turns off all the other transistors and so than makes a positive signal going into pin 3...
Don't you think it can give any kind of delay in the phase causing slightly lower frequency than resonance to be applied?
Or could it be to softening the signal?
I wire straight from pin 4 to 3 just like in the patent shows.
I simplified also the gated pulse frequency generator i use only 555 and 741 as in my schematic instead of 8 ics... it goes from 0 up to 100% duty cycle.
My pll system has only 8 ics including the transistor driver...
Nor i use the frequency dividers, i simply change the capacitors to change the range of the pll or gate frequency...
Another question is, why in the schematic posted the coils are not represented as in the original drawing where they were clearly opposing each other?
Best regards
« Reply #18 on: March 28, 2012, 21:05:41 pm »
Hey Tony,
Thank you for posting your hard work. Your continued help is greatly appreciated.
I also want to thank everyone else who has supported Stan's research and their commit to the project.  You guys are the greatest!!!
