Author Topic: Power Up of my 8XA  (Read 4488 times)
Power Up of my 8XA
« on: February 12, 2012, 21:28:55 pm »
Just did a quick power up of my 8XA, videos to follow
Re: Power Up of my 8XA
« Reply #1 on: February 12, 2012, 21:33:47 pm »
Cut the video down into 3 parts. I noticed the gating light is reversed. Easy fix.
« Reply #2 on: February 12, 2012, 21:36:04 pm »
Part 2
« Reply #3 on: February 12, 2012, 21:38:02 pm »
Part 3
« Reply #4 on: February 13, 2012, 02:16:14 am »
Congrats!
« Reply #5 on: April 17, 2012, 04:58:02 am »
Wow, your the guy I need to talk to.  I am looking at doing an 8XA card setup.  I gather from your video you get something close to 1 lpm at the 5A setting?  Was this a 12v DC reading?  I run conventional electrolysis with electrolyte and get about that around 15A.  Ideally I would like about 2 lpm, but I don't want to run 30A thru my car electrical system.  I gather you need a coil in the setup.  Do you have a schematic?  Where can I get some of the details using the 8XA?  The 8XA takes 12v AC, correct?  Is that Tony's card you are using?
« Reply #6 on: April 17, 2012, 12:55:21 pm »
* Shameless Plug *, but the 8xa kit is also available here, as well as many other places:
http://stansdream.com/products.htm
« Reply #7 on: April 18, 2012, 16:19:47 pm »
sampojo,
The 8xa circuit is a benchtop test unit.It uses ac line voltage of 110 volts.It needs the 120 hz thats generated by the ac voltage through a full bridge rectifier.The only way to use it in a car is with an inverter.Needs ac input.
