Author Topic: Figuring out the Steam Resonator  (Read 51284 times)
« Reply #96 on: February 13, 2012, 03:23:07 am »
From everything I've read between Meyer and Puharich, I would have to say Yes! :-)
« Reply #97 on: February 13, 2012, 12:57:14 pm »
Is this how the board should be connected?
« Reply #98 on: February 13, 2012, 18:24:06 pm »
Here are the connections.
(http://www.globalkast.com/images/tonywoodside/steam_resonator_circuit2.PNG)
« Reply #99 on: February 13, 2012, 21:27:16 pm »
Thanks for the clarification.
I will input 5V square waves and see what happens.
The transformer - it looks like a 1:1 - is that right?
Also, wouldn't some diodes be needed on the output to cut down the back EMF and
to protect the TIP120's, or is that what we are after?
I will try a few different ones to see which works best.
Wouldn't it be great if I could get some hot water!!
« Last Edit: February 13, 2012, 21:46:24 pm by waterfreak »
« Reply #100 on: February 13, 2012, 21:54:27 pm »
HMS - A named Peter Davey may hold the key to Stan's steam resonator tech and he is still alive, but he's in in 90's so we need to get to him before he dies!
(http://i41.tinypic.com/w7ge2t.png)
Interesting water-gap!
Stan Meyer 0.0950 inch = 2.4 millimeters
Peter Davey 0.0826 inch = 2.1 millimeters
Looks like Peter used "Three" frequencies: 350, 49, 1000Hz
So there must be a "key note" for the water molecule and use this fundamental frequency and put harmonic on it or enharmonic ?
http://www.ionizationx.com/index.php/topic,1305.msg22201.html#msg22201
Note:
If you have a fundamental frequency (sinewave) and then put a harmonic (sinewave) on the fundamental we get a new shape.
"There are several important aspects to this new shape.
First, its shape is not a simple sine wave, so it will sound richer than just a pure tone.
Second, even though the shape is different, the period and frequency are the same as the fundamental above.
This is very important, because it means that the pitch stays the same.
So, now we can see the connection between shape, harmonics and tone quality.
If add harmonics to the fundamental, we change the shape of the wave, but not its pitch, so this gives us a way of independently controlling the tone quality without affecting the pitch. It does not matter if we add a wave at 3f, 7f, or 32f. The shape will change but the pitch will not."
Br,
Webmug
« Last Edit: February 13, 2012, 22:23:21 pm by webmug »
« Reply #101 on: February 14, 2012, 03:05:50 am »
Here's something I want to test.
« Reply #102 on: February 14, 2012, 03:07:00 am »
The upload did not come out right. I will retry
« Reply #103 on: February 14, 2012, 03:19:36 am »
The tumb nail leaves off detail. Download the jpg. The plate connection is top center
