Author Topic: How to build the vic tried and tested  (Read 46685 times)
« Reply #24 on: August 17, 2011, 03:14:43 am »
The purpose of spirally wrapping the choke coils in the Tri-Coil Configuration is to minimize current leakage and to maximize the coupling coefficient to where as the L1 magnetic flux lines will be cut by the L2 flux lines.
« Reply #25 on: August 17, 2011, 03:49:31 am »
hi tony
i have a customer, but i disagree.., the only flux cutting secondary or chokes is from the primary. remember there is no current flowing in the circuit due to electron clustering, all electrons in the primary magnetic field align forming tiny bar magnets, they will have a magnetic field is this what you are talking about?
dude u look scary in that pic  :o
« Last Edit: August 17, 2011, 07:02:00 am by spintronic »
« Reply #26 on: August 17, 2011, 08:33:04 am »
HI Spintronic
Many thanks for sharing Your knowlege. My english is bad.
Can you clear this to my- only primary coil must be the iron wire , secondary and two resonant coils can be the copper wire , please?
I like learn from you.
thank
andy
« Reply #27 on: August 17, 2011, 08:46:42 am »
no problem andy
secondary and choke coils must be iron
primary iron or copper, copper still under test
hope that helps  :D
« Reply #28 on: August 17, 2011, 08:48:44 am »
why are you saying that the coils need to be iron and not copper?
« Reply #29 on: August 17, 2011, 09:10:28 am »
Thank Spintronic
andy
« Reply #30 on: August 17, 2011, 10:00:56 am »
hi tony
ok
The source of information is hard work at first, it gets easier.
Ferrous and non ferrous metals have very different propertys
Spin-polarized currents flow well in magnetic materials, but when they enter non-magnetic materials the electrons begin to lose their spin polarization in a process called spin-flip scattering.
source http://www.spintronics-info.com/technical/cold_copper_causes_spin_diffusion
in Copper wire each atom cannot form a north or south pole so meyers vic will not work. copper wire has not worked for over 4 years now.
Spintronics is an advanced form of electronics that harnesses not just the electrical charge of electrons (as in conventional electronics) but also a property called spin that makes electrons act like tiny bar magnets
source  http://leebor2.741.com/spintronic.html
inorder to stop current flow the electrons must form perfectly aligned magnets, they stick together (north to south poles) this is refered to as electron clustering. It is not 100% clear to me the physics but i know this works.
the magnetic field from the primary must be perfectly uniform. if not it will leak. even a leaky primary can be shown clearly to restrict current. a correctly wound primary will read zero amps on a multimeter that measure down to 10uA (test done on my vic).
Any questions please post, i dont know everything unfortunately. i know this works.
« Reply #31 on: August 17, 2011, 10:08:01 am »
But that is what the closed-loop core does. It maintains the polarization with in the closed-loop and minimizes the leakage.
