Author Topic: Water Fuel Cell Resonant Cavity dimensions/shape?  (Read 6189 times)
Re: Water Fuel Cell Resonant Cavity dimensions/shape?
« Reply #8 on: April 08, 2011, 15:01:26 pm »
Hi!
I have drawn the cell sketch in a cut. At me two question to Dynodon:
1. How the tube concerning a rod should be located?
2. On what depth it is necessary to do drillings in a rod?
Thanks.
(http://www.photoshare.ru/data/73/73838/1/4zymz2-ops.jpg)
(http://www.photoshare.ru/data/73/73838/1/4zynef-q3u.jpg)
« Last Edit: April 08, 2011, 16:25:16 pm by shadow_wfc »
« Reply #9 on: April 11, 2011, 22:27:31 pm »
Shawdow, it isn't that critical on how you cover the tubes.I have pictures somewhere on this site of my single tube set up.
The negative rod only needs drilled to the bottom of the slots in the sides.They don't need to be deeper than that.
The Tube set needs to be set in a delrin base,so you need four sizes of countersunk holes.
1st hole would be @ 3/8 inch say 2 inches deep.This would be the water inlet.
2nd hole would be 1/2 inch and 1-1/2 inches deep.
3rd hole would be 3/4 inch and 1 inch deep.
4th hole would be the outside diameter of the cover of the outer tube,say 1 inch and 1/2 inch deep.
Your first hole would need to go into your chamber for the water to enter.
Anything in that set up will work fine.Donaldwfc has a nice drawing on here somewhere.
« Reply #10 on: April 12, 2011, 06:39:22 am »
Thank you for reply Don!
I'll finish my drawing of whole setup now. I hope it will be closer to Stans work then ever.
Question to all: is it necessary to adjust weights of electrodes to the ratio 2:1? Hydrogen is released in 2 times more than oxygen...
    • Stan's Dream
« Reply #11 on: June 17, 2011, 04:44:28 am »
What is confusing is the resonant cavity has the tubes wired in series - how was it possible to wire each tube to it's own vic - or was this cavity as a whole connected to one vic?
This is hard to resolve, unless this is part of another system...
