Hello
I would like to take you all attention.
I found what could be happening in the amp restriction process.
First of all i'm going to tell you that when i said in the past charge pump, actually i was right cause the thing actually work like that but its called a current source.
A current source have infinite impedance thus does not matter the impedance of the source there will aways be that same current.
I recommend you all to read this article entirely
http://en.wikipedia.org/wiki/Current_sourceHere you see why in a dead short condition a constant current will still provide the same current even if voltage is 0.
And why a charge pump will aways charge a capacitor till its break down.
A van de graf is a charge pump too.
Now i'm going to introduce you the concept of the amp restriction.
Think of a resistor, if you ideally connected one current source (infinite impedance) to it a current will flow developing a voltage across its leads. Now if you apply a voltage source with counter "phase" polarity, you will have no current flowing thru the resistor therefore if you have infinite impedance across it a ideal current source and a ideal voltage source you can do create indefinite power. .
Meyer did this in the coil, in the water and in the air too.
I will explain.
The resonant charging choke combines a charge pump effect thus a constant current source, the resistor, and the voltage source.
Do you remember when meyer said that copper was better for voltage inducement. Well he was right.
If you take a coil of copper witch will have a certain current flowing thru it and you have another coil this made of resistive wire as for it will have a current flowing into it in one direction and a voltage being developed in the other direction.
The magnetic flux accomplishes both works.
There must be a resulting inductance as for it to behave as a charge pump. The amount of charge pumped depend on the voltage of the coil you designed. So the secondary charge the diode block and the coil give the extra charge.
I think that the coil can be made especially to control it perfectly i'm just thinking of that.
So again the current flowing thru the coil develop a voltage cross it, than you can simply apply a voltage to it or you can induce or whatever way we found that work well.
Very interesting?
So we can do in a variety of ways.
Ps:Steve because of the login i just wrote all this and that i'm going to write again now cause asked logging when i replied third time today...
