Author Topic: Stans theory on bringing atoms in an unstable state  (Read 7726 times)
Re: Stans theory on bringing atoms in an unstable state
« Reply #8 on: January 29, 2011, 23:21:43 pm »
I think this coils are for creating the magnetic bottle, in witch the electrons emitted from the filament together with the ions being deflected by the anode field create a vortex witch makes the electrons to get trapped in the surrounding tube. This create a voltage that than can be discharged in order to take the electrons away.
An electron when flying perpendicular to a magnetic field curves. The geometrical configuration is very important and should not be over looked.
« Reply #9 on: January 30, 2011, 00:44:22 am »
whats interesting to read is Memo WFC 422 DA, copy attached, it helps make clearer the overall view of the system design for i was getting confused with the laser accellerator, now it comes clearer why he used IR led's paired with IR receivers....
what pointed me to that memo was a comment found on another blog thru google,
"the LED in the GP are not red, they are ultraviolet look at the patent Memo WFC 422 DA page 3-23, in addition to ionization of the area ambiente must use UV 400 to 250 nm is not IR."
« Reply #10 on: January 30, 2011, 01:41:40 am »
Oxygen will absorb and emit ultraviolet, while, Hydrogen will absorb and emit infrared... So, I assume he used both at one point or another. In fact, in the tech breif he illustrates how to make a laser device with the use of ionized hydrogen to emit infrared.
« Reply #12 on: February 01, 2011, 07:51:46 am »
Atomic and molecular excitons
Atomic and molecular excitons Alternatively, an exciton may be thought of as an excited state of an atom, ion, or molecule, the excitation wandering from one cell of the lattice to another.
When a molecule absorbs a quantum of energy that corresponds to a transition from one molecular orbital to another molecular orbital, the resulting electronic excited state is also properly described as an exciton. An electron is said to be found in the lowest unoccupied orbital and an electron hole in the highest occupied molecular orbital, and since they are found within the same molecular orbital manifold, the electron-hole state is said to be bound. Molecular excitons typically have characteristic lifetimes on the order of nanoseconds, after which the ground electronic state is restored and the molecule undergoes fluorescence. Molecular excitons have several interesting properties, one of which is energy transfer (see Förster resonance energy transfer) whereby if a molecular exciton has proper energetic matching to a second molecule's spectral absorbance, then an exciton may transfer (hop) from one molecule to another. The process is strongly dependent on intermolecular distance between the species in solution, and so the process has found application in sensing and molecular rulers.
« Reply #13 on: February 02, 2011, 09:37:58 am »
well, i dunno about any of you but reading through the many pages of info its easy to get confusion about the parts and labelling, ie the gas resonant cavity, ambient air ioniser and laser accellerator..... as all 3 initially appear similar due to the use of LED's.
Re: Laser Accelerator functionality
« Reply #14 on: April 25, 2011, 11:50:29 am »
THE "LASER ACCELERATOR" IS SIMPLY A FANCY TERM FOR "gAS PEDAL" THAT USES PHOTODETECTORS TO SENSE THE POSITION OF A MOVING METAL TAB BETWEEN TWO ROWS OF LEDS AND DETECTORS...THIS POSITIONING DEVICE WAS DESIGNED TO LAST A LONG TIME, EVERY TIME YOU STEP ON THE GAS PEDAL THE CABLE ON THE DUNE BUGGY WOULD MOVE THIS METAL TAB, RESULTING IN A FEW LIGHTS PASSING THRU THE GAP OR ALL THE LIGHTS PASSING THRU THE GAP. eSSENTIALLY THIS IS SIMILAR TO A LINEAR VARIABLE RESISTOR, EXCEPT THAT THERE ARE NO PARTS TO WEAR DOWN.
So the result is any number of 5 volt signals 1 to 15 sent to the figure 2 multiplexor chip which in turn shaped the pulses from 10% duty cycle to 90% duty cycle based on the position of your foot on the gas pedal...
this in turn sent anywhere from 3 volts to 12 volts to the positive side of the VIC Coils to control their gas output or hydrogen production.
its that simple !
« Reply #15 on: April 25, 2011, 12:25:47 pm »
This is one of his most amazing developments. He is "flexing" the "energy aperture" of the hydrogen atom which allows universal energy to enter this three-dimensional portion of the universe. Like he explains, with the electron spinning around the proton, it should collapse into it in a billionth of a second, the forces require it, however it does not happen because energy is constantly being drawn into the atom structure to maintain it's stable state. This energy that is constantly being drawn into the atoms to maintain their existence can be manipulated by putting the atom into a non-equilibrium state where an increased amount of universal energy is demanded by the atom to maintain it's existence. Doing this in a controlled manner allows him to release energy directly from the atoms without reacting or destroying them. The kind of energy that comes out is electromagnetic energy, of which light is merely a select frequency range of the larger spectrum. He calls it an EASER, where the E stands for Energy, instead of an L for Light in LASER. Energy (Light) Amplification by Stimulated Emission of Radiation
