Author Topic: tube cell 1.0  (Read 12410 times)
Re: tube cell 1.0
« Reply #8 on: April 03, 2011, 06:39:22 am »
Well I have a week off from school so I’m going to try to get as much done as possible!
My test cell is pretty much done. I know it’s not the neatest thing in the world but it will serve the purpose. I gave myself a lot of options with this one.
I have two optional ground connections for the inner tube and/or water. I took the inflation part of an old bike tire, so now i can put the cell under pressure using an air pump or whatever. The cell is designed to have water pumped through it. I'm just waiting on the one way valve to come in the mail, but I have constructed the pump system. I also found a cheap hot tube pressure gage but it’s only meant for water; that’s why I mounted it at the bottom. Hopefully in the next few days I’ll have something cool to share, but then its back to school till summer.
Here’s some pictures
Re: tube cell 1.0
« Reply #9 on: April 03, 2011, 06:44:40 am »
heres a better picture
Re: tube cell 1.0
« Reply #10 on: April 07, 2011, 18:34:11 pm »
it works pretty well, not sure how to insert the video into the text box but heres the link
http://www.youtube.com/watch?v=SKXMQZWV_Rk&feature=mfu_in_order&list=UL
« Last Edit: April 07, 2011, 20:35:25 pm by Dave »
Re: tube cell 1.0
« Reply #11 on: May 27, 2011, 02:27:02 am »
Got the pump hooked up, forcing water through the tubes does some cool stuff!
I think this is one of the reasons Stan's system could go through 5 gallens an hour.
Re: tube cell 1.0
« Reply #12 on: September 07, 2011, 04:31:53 am »
http://www.youtube.com/watch?v=3ipfxwu40Ow
made a video of my tube cell producing with and without the pump
Re: tube cell 1.0
« Reply #13 on: September 07, 2011, 19:15:32 pm »
So, no major improvements with the magnets, Dave......... ;)
Well, you did see the improvement of the waterpump .
Not a bad score    ;D
Re: tube cell 1.0
« Reply #14 on: September 09, 2011, 20:53:11 pm »
I did some tests a while back with forced water circulation through the water capacitor to see if it would reduce the leakage current.
The leakage current was the same with and without the water circulation. Even with a pump that forced a large volume of water through the capacitor.
I think Meyer's circulating system reduced leakage current, but only because it pumped the water through an electrostatic filter.
« Last Edit: September 12, 2011, 02:45:33 am by sebosfato »
Re: tube cell 1.0
« Reply #15 on: September 09, 2011, 21:24:59 pm »
Thanks Steve I'm happy with it  :)
HMS what kind of electrostatic filter was Stan using? was it similar to an air filter?
