Author Topic: How much gas from 1 litre ?  (Read 8150 times)
Re: How much gas from 1 litre ?
« Reply #8 on: October 14, 2010, 07:16:03 am »
You may want to take into account the energy required to turn the alternator in your energy in side of your equation
« Reply #9 on: December 06, 2010, 19:54:24 pm »
In terms of thermal explosive energy-yield (gtnt) under dynamic pressure of compression
approximately 7.4 (µl) microliter of a liquid-volume of a water droplet per injection cycle is all that ~s
required to run the Dune Buggy 1600cc 50hp VW I.C. engine at 65 m.p.h. on the open road; whereas,
a typical 325 hp diesel I.C. truck-engine would require about 48.1 (µl) microliters of a water droplet
per injection cycle to accomplish the same open road performance. (see WFC Water vs Gasoline
Energy Content Equations (memo WFC 429).
How much LPM water is this for the typical diesel truck?
« Reply #10 on: December 06, 2010, 23:22:52 pm »
48 uL per power stroke... lets round to 50 uL
1/4 cycles are power stokes
say 2000 rpm? ... then ...
500 power strokes per minutes
50 uL * 500 power strokes /min = 25,000 uL/minute
= 25 mL/minute, or you could say
40 minutes per liter...
thats the basic idea, change the numbers to match your rpm and engine (2 stroke or 4 stroke)
The above number, 50 uL per injection cycle, is based on the hydrogen content of water being 2.5x gasoline, you can see this calcuation done out in full in the independent report, it's not a magic calculation that has anything to do with the WFC tech, so it's the same as saying a diesel engine uses 20 uL per injection cycle of Diesel fuel... which would vary depending on your engine
« Reply #11 on: December 06, 2010, 23:35:54 pm »
Thanks.
Now let's hope the water doesn't get consumed, or else we'll face a different problem  ;) .
« Reply #12 on: December 06, 2010, 23:38:30 pm »
If the water does get consumed, like in the Hydrogen Fracturing Process, then this releases more energy than 2.5x gasoline.... Stan says the HFP gives 2,500,000 barrels of oil worth of energy for 1 gallon of water, this is if you completely destroy it to release the mas energy.
With the HFP you would power the WHOLE WORLD with 34 gallons of water a day (being destroyed... approx)
