Author Topic: Resonant waterfuelcell project by Steve  (Read 29830 times)
Re: Resonant waterfuelcell project by Steve
« Reply #16 on: September 30, 2010, 23:32:24 pm »
I was thinking about the ferritic wire and i realized something
Stan say 60uohms per centimeter witch would totalize 6ohm per kilometer http://www.powerstream.com/Wire_Size.htm
If was copper wire witch is not resistive would be +- 13awg or 1,8mm diameter... however is stainless steel witch is maybe 10 times less conductive than copper... This would be very thick wire... Do you agree?
Than i found the principle behind the electron bounce phenomenon, its all about the ability of the ferritic wire to become permanently magnetized, this perform a function of magnetic resistor... So the wire is not thin to create this resistance otherwise current would be restricted by ohmic resistance thus dissipating heat... The magnetic resistor restrict the amps by creating a reactance like effect... Stan was a genius.. Its generally used for sensing, siemens have sensors using this principle...
You could use a permanent magnet to restrict the current as to be able to tune this resistance too...
You all should read all the tech brief again. And once again if possible.
Every thing this man said was true.
I have tried last year a this thing about approaching a magnet to the transformer while i was using a kind of steel wire I had and I got really higher voltage and less amps just like but in a different way to the way I showed in the video... However I commented this and was told by others that i was ridiculous .. in the energetic forum i guess... I than got the transformer destructed during a resonance that i achieved, the transformer became flash light blue like a neon lamp and after some seconds started to burn...  All the turns was blue... Thus i lost all the wire because it went destructed... I found a good supplier for ferritic wire here and tomorrow i will go there and he will give some for free... =)
I spoke to My neighbor today and he has an old oscilloscope 5Mhz and he will borrow it to me if it still working, the only problem is that it still don't see dc voltage because its capacitive coupled. Cool however...
Stan say somewhere that the amp inhibiting coil have its own inductance core... when talking about the sync pulse schematic i guess
I would like to know from you that have english as mother tong what exactly you understand by this:
axially (spiralled) Bifilar wound about core bobbin (502), forming individual spiral-wrap (inner to outer circumference and being equally-length) coils (501a xxx 501n) electrically connected in sequencial order to form resistive pickup coil (503).
more to come...
« Reply #17 on: October 01, 2010, 00:18:00 am »
I read that he used multiple pancake like coils in serie on 1 core...
You see them in his documents, very often, Fabio.
« Reply #18 on: October 01, 2010, 00:41:48 am »
Yeah i know, Is just that re reading axially bifilar, inner to outer .... it made me think about what is the best way to wind up like this...
In the drawing he show this inner to outer coil as being magnet wire... and the thin wire as resistive choke
in the book he states that this drawing is not correct in the sense that is not complete, the energy don't get into it by the wire terminals... with the circles...
what about the ss wire 60uohm centimeter ? what do you think steve?
« Reply #19 on: October 01, 2010, 01:05:18 am »
I remember Stan saying that you can make his circuit work with or without SS wire.......
He just mentioned it, because of patent protection.
So, simple plain emailled copperwire must be able to do the trick...
« Reply #20 on: October 01, 2010, 01:16:55 am »
yes i think it can work too but i believe that the fact is that its not only about ohmic resistance but impedance Z caused by magnetic flux not self inductance also for the copper causing skin effect... SS wire would need many times less turns however..  well i don't know... will try and than i tell you=)
This phenomenon of transferring voltage waveforms along an electrical conductive surface is known in the field of physics as the Skin Effect.
thanks
« Reply #21 on: October 02, 2010, 00:25:01 am »
« Reply #22 on: November 01, 2010, 23:21:31 pm »
« Reply #23 on: November 02, 2010, 03:47:17 am »
You guys, The afore mentioned link to the energetic forum is not an avalanche effect. He has his terminalogy mixed up...
Google the avalanche effect it has to do with voltage overloads.
