Author Topic: Bob Beck Blood Electrifier  (Read 28486 times)
Re: Bob Beck Blood Electrifier
« Reply #16 on: October 21, 2010, 22:23:11 pm »
While I'm using the device I became i little confused. I measured the Hz output and it was 40 Hz.
40 Hz is the most save value to use the system but I wanted the more stronger setting like 4 Hz. I replaced the little 103 ceramic capacitor 0.1 uF, with a electrolytic capacitor 0.1 uF, and bingo I got the 4 Hz running. The only thing that is not good is the voltage output. It should be 27 volt on the two output leads. My batteries are absolutely full but I get only 5 to 6 volt max. That is not good enough, anybody a suggestion? I used the device for some days and I noticed noting on my body, just a slight tingle on the skin, noting more. The demonstration video's showing a much stronger appearance, the users must temper the voltage always with the potentiometer. I saw the fingers of somebody react in the rhythm of the 4 Hz.
(http://www.sumopaint.com/files/images800/igeiffzgtjclliei.jpg)
« Reply #17 on: October 22, 2010, 00:29:27 am »
Just put it on 7,8h till 8 hz, Knovos. Thats a frequency that your body uses for regeneration.
Becarefull with other frequencys. Read on google for Rife (royal rife) They have lists of frequencys.
« Reply #18 on: October 22, 2010, 01:47:35 am »
if you are not getting the 27 volts then check the resistance... use the ohm meter to check while you play with the pot and compare to ohms law, and the volt meter to compare too
« Reply #19 on: October 22, 2010, 23:28:16 pm »
Thanks Donaldwfc. I replaced 3 resistors and both a new potentiometer. The device works ok now. I have to temper because the highest setting is way to strong! Now I must start all over again with the schematic, just a bad start.
Thats a great link Steve. I did not know there is so much research on micro electro healing. All those frequencies and so many different diseases. There is a lot more to explore but I will first stick to the normal Bob Beck method with 4 Hz.
Knovos
« Reply #20 on: October 25, 2010, 02:45:30 am »
I ordered my parts from digikey,  should be here in a few days or a week or so, then i'll build it!
« Reply #21 on: October 25, 2010, 20:40:44 pm »
Good luck with the building Donaldwfc. I ordered some extra components too for making the design with the one 9volt battery. Should be nice to have a device which is as small as possible. I have also ordered stuff  to build the Bob Beck magnetic pulser. Another device which have great healing possibilities also, its one of the 4 components of the Bob Beck protocol.
« Reply #22 on: October 25, 2010, 21:51:53 pm »
When it comes to bob beck's magnetic pulse i think it has been surpassed by Marko Rodin and Jamie Buturff.. both of them have made a unique style of coils which seem as if they would be benificial for inducing pulses into the body..
Jamie Buturffs coil seems like a good one to replicate.. He calls is a Vesh 432.. he says the 432hz is interrelated with the solfeggio frequencys which are known for energetic healing..
(http://i82.photobucket.com/albums/j243/outlawstc/vesh432.jpg)
(http://i82.photobucket.com/albums/j243/outlawstc/vesh432-2.jpg)
                        If  all matter is energy in vibration (E=MC^2), then what is the frequency  of that vibration? It's all harmonics of the A=432Hz - not 440 Hurts.  I've seen too many people experience wonderful results on my coils and  harmonic sounds to know any different. The lower octaves are 216 and  108. See anything familiar with these numbers?
 the interesting thing about the Solfeggio  frequencies is they are all harmonically separated by the 432 and are a  trinity of family number groups 1,7,4 - 2,8,5 - and 3,9,6. For example,  take the first solfeggio of 396 and the four...th  solfeggio which is 639, one digit shifted to the right and the same  number group. If you subtract the two numbers you get 243 which is 432  shifted one digit to the right. This applies to all 3 solfeggio number  groups!
You see, the solfeggio is a code - one part unlocks the  proper frequency of natural vibration but also gives us the harmonic  interval of the rhythm that accompanies the 432 frequency in the 1,7,4  - 2,8,5 - and 3,9,6. This is the symphonic code of the universe!
 The solfeggio is a beautiful code that gives us so much more
« Last Edit: October 26, 2010, 03:06:50 am by outlawstc »
« Reply #23 on: October 25, 2010, 22:26:28 pm »
That is a beautiful made device what you showing there. I have heard from a rodin coil but not the name Jamie Buturff. I picked the Bob Beck device because of the big community that's behind there using his devices. They are building other variations these days, like
http://www.members.optusnet.com.au/~aklemens/
Concerning the pulser device it is the best way to build something that works and make later on some improvements if necessary. I 'l keep that 432Hz in mind. Thanks.
