Author Topic: 3 phase circuit  (Read 8080 times)
Re: 3 phase circuit
« Reply #8 on: April 16, 2008, 09:12:02 am »
I see a lot of work there H20power. Wow that bobin in your cad drawings looks like the lhc. You look very determined.
 Any good results ?
hm
Re: 3 phase circuit
« Reply #9 on: April 16, 2008, 12:41:56 pm »
Hi H2Opower,
Its nice to read your enthousiasme about the VIC.
Why are you building a 3 phase circuit, if you so far with the VIC?
About the schematic of Dingel. Is that all info you have? Is there more info on that part in your library?
I can understand your theory about stepping up voltage.
A bifilair coil is stepping up voltage. So, yes you will increase voltage.
About Bemf, i have made a simple circuit for testing this.
http://ionizationx.com/index.php?topic=200.0
The voltage peak without load is very high. Only when you add a load, like a very low ohm wfc, the peaks will drop to normal levels.
Did you find a workaround for that problem?
steve
