Author Topic: Starting at the Genesis of Stanley Meyer's Work - The Demo Cell  (Read 46167 times)
0 Members and 25 Guests are viewing this topic.
Re: Starting at the Genesis of Stanley Meyer's Work - The Demo Cell
« Reply #32 on: August 08, 2010, 18:27:37 pm »
Dynodon told me he saw a picture of that stator on a table with the ~18 or so 36 gage wires sticking out of it.
« Reply #33 on: August 08, 2010, 22:28:00 pm »
...Anyway, hope this helps and Mena doesn't think this is cluttering up the thread.
Mike
@Mike:
No Mike, you are not cluttering up this thread.  I wrote the introductory “ground rules” (for the most part) to scare off people who come into a thread such as this one to say that Meyer was a fake or a fraud and his technology will never work and then proceed to bash everybody posting in the thread with childish name calling.
Your comments are directed towards the underlying secret of the demo cell (and also the theme throughout Stan’s work in general) which is letting the voltage do the work without significant current flow.  This is completely relevant.  It is also what I hope to achieve as well.
Thank you for your input.
Regards,
mina
« Reply #34 on: August 09, 2010, 04:07:48 am »
Mike
@Mike:
Regards,
mina
Thanks mina
I don't want to post a bunch of B.S.  I'm tired of reading crazy theories that don't make sense.
Mike
« Reply #35 on: August 17, 2010, 16:55:09 pm »
Hello everybody,
I just popped in to post a little update.  I purchased two single phase AC motors.  One of these motors really screams at 3450 RPMs :o   With this motor, I should be able to drive an alternator with a one-to-one pulley ratio.  Experimenting with various pulley combinations will allow me to test the cell with RPMs in the high 9000 range on down.  It’s an additional test parameter (the RPMs) I will be disclosing in my experiment results.  Once I determine the best RPMs, I can use my more efficient AC motor with the proper pulley ratio and find out if it can handle the load.
I believe Stan’s motor was a 1725 RPM capacitor start motor with something in the neighborhood of a one-to-two or one-to-three ratio.  I just want to try higher RPM ranges to see if there is any noticeable increase in performance.
I will be having my tubes TIG welded this weekend and I plan to take some pictures at the welding shop.  I will be posting more pictures some time next week.
Later this week, I plan to post “Meyer’s Preliminary Stages Part 2”.
Thanks again for ALL the input everyone has been giving.  I really can’t thank everyone enough :)
Regards,
mina
« Reply #36 on: August 17, 2010, 22:43:34 pm »
Good stuff!
The rpm will effect the alternators output frequency only, and since Stan also superimposes another frequency into the input of the alternator, I expect this frequency to be of the prime importance, for turning and matching, while the natural frequency from rpm is of secondary consideration, although they clearly interact with each other.
Another factor is the inductance of the alternator, which depends on the amount of turns, and the size of wire you use to rewind it.
All of these values being match to the cell...
« Reply #37 on: January 24, 2011, 05:27:12 am »
The "L" bracket figure verses the figure "7" figure for the bottom of the outer .75" tubes:
« Reply #38 on: January 26, 2011, 07:20:08 am »
Clip and Wire Present...
« Reply #39 on: January 26, 2011, 07:22:47 am »
Clip and Wire Missing...
