Author Topic: The Master Plan  (Read 6215 times)
Re: The Master Plan
« Reply #8 on: July 14, 2010, 05:59:26 am »
Why ask for help instead of learning the ropes ?
If you get demotivated by others opinions than you aint stopped bein demotivated .
Re: The Master Plan
« Reply #9 on: July 14, 2010, 06:52:59 am »
Dankie... as a member that jumps from idea to idea claimin importance before testing, also as someone who shares nothing of relative importance other than "i have the answer but it is patent pending so i'm not showing anyone"... Your very opinionated on what is worth someones time... With your opinion you might want to check what the boards are about before attempting to demotivate someone.
IMO i find your opinions vapid and conceeded. Your "discoveries" as mainly self propelled hype and your proposed experiments broad and always inconclusive, if they are every finished.
As a quote from a very mediocre movie "i can't go straight from A to D... i need the B and C" applies to pretty much everyone here on these boards you seem to be the only one who doesn't get it, or thinks it doesn't apply to them. As this isn't the fight board i'm going to leave it there...
Outlaw,
I am interested in your frequency results regardless of what the Jester is doing!
Re: The Master Plan
« Reply #10 on: July 14, 2010, 07:35:50 am »
You know what my projects are , I dont know VVTF you are talking about .
Nobody can tell me anything about not sharing enough or not doing enough for the public forums .
Re: The Master Plan
« Reply #11 on: July 14, 2010, 14:48:05 pm »
dankie we know that nobody can tell you anything because you are in your own conceded world.. i would like to put in a request that you do not participate on my threads anymore.. i am not interested in the peanut gallery on my threads.. I'm honestly sick of your non pro remarks that do not resonante motivation in the proper direction for most.. you do not effect my motivation dankie i can not be manipulated by your jargon. just aggravated
« Last Edit: July 14, 2010, 15:22:08 pm by outlawstc »
Re: The Master Plan
« Reply #12 on: July 14, 2010, 14:51:33 pm »
Re: The Master Plan
« Reply #13 on: July 16, 2010, 07:33:59 am »
must be the nth time i have seen that video linked!!! sometimes i wish i lived in the states to go to some of the stuff there but its a little more expensive to fly from down under
Re: The Master Plan
« Reply #14 on: July 16, 2010, 08:42:38 am »
These frequencies this guy is talking about in the video where not discovered by him...Henry Puharich talks about these types of frequencies in his unpublished book.  As Puharich discovered that an 8Hz Magnetic B-wave will tell the body to repair its DNA and he also discovered that this same 8Hz frequency was present in his water splitter device.  He says it is one of the main components aiding in splitting the water molecule. Puharich also noted that when splitting water, this 8Hz B-wave would create tiny organisms in pure water. The 8Hz frequencies in the water splitter where sidebands created by the main AM frequencies. He gives the resonant frequency of his system as 600Hz. The 600Hz is the center frequency, or Wr, and the +Delta W is 360Hz and the -Delta W is 720Hz...these two frequencies cross paths around 512Hz which creates the 8Hz B-wave frequency. Ok had to add my 2 cents  ;D
Re: The Master Plan
« Reply #15 on: July 16, 2010, 09:51:57 am »
I worked with the 8hz frequentie in the past on another project.
This is like the schumann earth frequency 7.8hz till 8hz, depending where you life on earth.
This frequency is for repairing / regeneration of cells of all living creatures on earth.
Not sure if it is helpfull in destroying molecules of water.
It should do the opposite in my opinion...
