Author Topic: Hydrocars Tube Build #2  (Read 8373 times)
keithturtle
Re: Constructing The Tube Holder #2
« Reply #8 on: January 17, 2008, 03:43:54 am »
I had some good success with implementing the above strategy.   I made 13 pipes with the 1/4" bolt welded to one end.   Most turned out aligned within 0.010" and the ones that were way off got slapped back into shape with a big pry bar.
Gonna drill some circulation holes then prep 'em for installation in the 3-tube cells.
One set will git epoxy-primer coated to 2 mils thick for that experiment as well.
Slow but sure progress.
Turtle
hydro
« Reply #9 on: January 17, 2008, 08:00:45 am »
some more pictures
« Last Edit: January 17, 2008, 17:24:36 pm by hydrocars »
keithturtle
« Reply #10 on: January 19, 2008, 03:50:16 am »
Good progress, man!  If all of the inner or outer tubes git the same signal, y'all might could make a ring plate drilled to fit all the bolts at once and jes have one connection
Turtle
Kevin
« Reply #11 on: January 19, 2008, 05:09:59 am »
This is really impressive Hydro.  Can't wait to see it in action.
Keep up the good work!
-Kevin
« Last Edit: January 27, 2008, 03:19:35 am by Kevin »
hydro
« Reply #12 on: January 19, 2008, 06:58:14 am »
here be my L angles. glad its over with!!!! ! ! !! ! ! !
oh, and my old tube beside my new one LOL , i even added rubber bumpers to the bottom of the cell.
« Last Edit: January 19, 2008, 07:03:13 am by hydrocars »
hydro
« Reply #13 on: January 21, 2008, 21:39:52 pm »
i will make a parts list for where to get the parts to build this cell asap
« Last Edit: January 21, 2008, 21:48:51 pm by hydrocars »
« Reply #14 on: January 22, 2008, 09:53:59 am »
Looking good Kevin!
up to your first tests!
steve
  • Pochin Hydrogen
  • Hydrogen to Drive
    • PochinTwin Hydrogen
« Reply #15 on: January 22, 2008, 22:17:07 pm »
nice variac like mine
