Ok, this will be fun, i'll get this RVIC wound then I'll start looking into pulsing it, i'll also be thinking about building a new cell or two, depending on what I want to experiment with next, I really should have built a larger tubular array, but I was just working with what materials I had. Variable spacing plate cell would be really nice to play with.
I've been re-reading some patents and have some new things to think about. It appears that stans pulsing circuit had some options that i've never seen any of you guys play with, as well as the actual "resonant cavity" phenomenon... it's not just a name, it's a description of how you get that pulsing and get the water resonating back and forth like air between a tuning fork or something, a physical motion of the water matched to the electrical pulses, this is important too.
I think stan played with a lot of stuff before he came up with the VIC, which shows that we should be able to get some results with different configurations, but we really need to plan our experiments to achieve the things he was trying to do, restrict amps, simultaneous pulsing of positive and negative voltage, gating and pulsing...
I suggest you guys take a read thought some of his earlier patents and really try to visualize his set up and match that with other stuff we know about his set up. all the patents are cleanly posted in my section.
