Author Topic: Demonstration Cell - Variable Spacing Plate Cell  (Read 42361 times)
Re: Demonstration Cell - Variable Spacing Plate Cell
« Reply #80 on: June 09, 2010, 19:53:28 pm »
Power consumption is not 12 W - many times more!
siwa
I mean is not 12 W in your video Don
« Last Edit: June 12, 2010, 22:11:26 pm by siwa »
« Reply #81 on: June 10, 2010, 02:34:48 am »
Power consumption for Stan is 80 volts * 5 amps = 400 watts for this set up.
(http://img.photobucket.com/albums/v81/bigbuba/Picture15-5.png)
I'll be sorting out my results soon enough.
« Reply #82 on: June 10, 2010, 04:00:33 am »
Added D1, it appears that when I go above 50 volts, the choke stops making noise, so maybe the SCR is latching, and dropping the voltage just a bit will bring it back.
« Reply #83 on: June 12, 2010, 04:09:42 am »
well done donald thanks so much for sharing some videos!!  are you controlling the gating with stans circuit that goes along with 8XA or are you using another circuit to gate the scr?
« Reply #84 on: June 12, 2010, 04:33:53 am »
just a pulsing circuit, no gating there
« Reply #85 on: June 12, 2010, 06:09:31 am »
tell me what you think of this device donald.. we should be able to hook the gat of a scr right to these and have like 5hz-10mhz pulse range with gating i think..
http://cgi.ebay.com/Datapulse-101-Systron-Donner-10MHz-Pulse-Generator-/370386664122?cmd=ViewItem&pt=BI_Signal_Sources&hash=item563cc3faba
« Reply #86 on: June 12, 2010, 06:18:39 am »
looks like it might work for a test set up, eventually you will need pll, not too expensive, give it a try if you want!
« Reply #87 on: June 12, 2010, 06:42:16 am »
just grabbed one for 53 bucks and will be here in around 4-7 days..  im gonna get some scr's and the parts to wire up my new variable next.. i also have a delrin bobbin and some 18 gauge i can wind on it as well as a ferrite e-core.. then i have the single resonant cavity
