Author Topic: VIC controller  (Read 21971 times)
Re: VIC controller
« Reply #40 on: November 27, 2011, 20:16:40 pm »
Good question! I did not pay close attention to that "ct and diode" before. I have understood the diagram more like the illustration below. I honestly have no clue where the ct would connect if at all. It is possible it could be an open/unterminated part of the circuit.
Re: VIC controller
« Reply #41 on: November 27, 2011, 21:31:57 pm »
Using the bifilar secondary he creates two vics in one... so he can create the opposite polarities...
Re: VIC controller
« Reply #42 on: November 28, 2011, 16:22:46 pm »
bubz and sebo thanks for your replys. Been doing a little more research on the center tap winding. Looks like it used for balancing between the two halves. the mismatch of the two coils flows through the center tap trying to equalise the two. The coil with out any dot orientation is usually wound the opposite way. (opposing) Sometimes it is used to reduce magnetic hum in components. thats probably. one of the reasons the amp restricting coil is on there is to bring that part of the system back in to phase with the secondary biffilar coils. From some of the other research the center tap could be reconnected back to the other center tap windings to bring that part of the system back in to phase with the wye windings of the alternator. It sound logical but havent tried it though. just have to try to figure why the diodes are placed like that.
