Author Topic: 3500 rpm on water......  (Read 15742 times)
Re: 3500 rpm on water......
« Reply #8 on: November 12, 2009, 21:33:17 pm »
can you use it on an electrical generator instead of a motorbike?
or calculate how much power the bike draws at 3500rpm?
it's all about the numbers  ;)
« Reply #9 on: November 12, 2009, 21:38:50 pm »
Good questions.
I start to hate my power generator a little bit. Thats mostly because its a 1 cylinder engine and has a waistspark. My bike doesnt.
Its also clear to me that a bigger engine works better then a smaller one, in my case.
My bike has around 85bhp at high revs..... I will look up to see what how much power it has at 3500rpm...
« Reply #10 on: November 12, 2009, 22:09:47 pm »
i'm no expert but could there be a difference to power when you drive at 3500rpm or when you idle at 3500rpm? so that the power consumption of your bike in idle is below this 1300W?
« Reply #11 on: November 13, 2009, 00:42:18 am »
Of course, you need more power to drive then to idle.  You can hear the power when i rev the engine. Its absolutly not without power.
Well, i hope it inspires you all! It did to me  :)
« Last Edit: November 13, 2009, 12:55:29 pm by Steve »
    • WaterfuelForAll
« Reply #12 on: November 13, 2009, 10:47:44 am »
Stevie
This is EXCELLENT!!  Well done!!!
Did you make any important changes to your 60 series cell, I assume it is a 5 series x 12 in parallel, or 6 x 10?
Are you using NaOH/KOH?
Wouter
« Reply #13 on: November 13, 2009, 13:14:54 pm »
Stevie
Wouter
Wouter, i changed my view on things a bit.
As you know, i ran always on tapwater without naoh or koh.
But there are 2 big issues with that.
1. its less efficient
2. The brown scum is terrible, even with all the filters in the world.
The only way to get a reasonable production with tapwater is with a tiny gap and the brown scum likes it there very much. So, my plates have been sanded for the third time in half a year now.
So, current cell is with the same plates of 30cm by 10cm. But it has now a gap of 1mm in stead of 0.5mm.
I was advised to go to 3mm, but with my low height of 10cm, it can be reduced to 1mm.
Thanks to Ausepom, i switched the holes per plate, meaning, not 1 hole is in a strait line with the next one.
I also played now for first time with KOH and NAOH. It seems my cell like NAOH a fraction better.
Its not the best cell in the world, but for the plates i have, it does a good job.
All 60 plates are in serie. Accoording to Faraday it does a 87%.
I tried other options, like 5 series of 12, but what i try, i always end up with one big seriecell.
To be honest, 50 plates would be the best, but i needed more gas, so i added 10 extra.
I have some plates left, so maybe i will make me a 13.8V version as extra.
Does your tubecells still doing 95% efficiency?
    • WaterfuelForAll
« Reply #14 on: November 13, 2009, 20:47:46 pm »
Very nice!
The "WaterfuelForAll" 6 series tubular design does 2 liter per minute  @ 20 amps, 13.8VDC.  At room temperature this converts to 2.16W/lph which is 93.9% Faraday efficiency.
How many Volts are you supplying to your 60 plate cell? (My guess would be around 140V)
So are you saying that with a "normal" series cell consuming +-1300W you are able to run your 600c bike at 3500 rpm? Do I understand you correct?
Wouter
« Reply #15 on: November 13, 2009, 21:40:23 pm »
Very nice!
Wouter
Hi Wouter,
60 plates = 59 cells
Volts/amps needed to run the bike on 3500 rpms = 124V by 11A = 2,10V per cell
Volts/amps needed to idle the bike on 1000 rpms = 122V by 9A =  2,06V per cell
The amount of litres HHO is very difficult to measure. This, because i use a 1,5ltr bottle and it filled in seconds....At 9 amps its like 6/7 litres a minute...At 11A it does like 8/9 litres a minute.
If you send me 10 of your 2 litres a minute cells, i will demo for you a running car!
Ps.
I will try tomorrow a 1.4 litre Renault Clio. See if it will idle..... ;)
