Author Topic: Geet project of Steve  (Read 36101 times)
0 Members and 17 Guests are viewing this topic.
Re: Geet project of Steve
« Reply #56 on: September 23, 2009, 22:56:27 pm »
Found some hours to run geet tests.
Fuel: 50% used motor oil and 50%  water.
NO RESULTS. Meaning, it didnt run whatsoever. I added some petrol and then it ran. Hmmmmmmm. Not good, is it.
Fuel: 50% used motor oil and 50% water and 2.5litre HHO p/minute
Engine ran perfect! The engine actually ran on HHO. When i took the HHO, the engine stopped directly.
STUPID ME: i used a glas bubler for the Geet tests. Well, if you put HHO in the bubler, like i did, you take a risc. I knew the risc. And i learned it again. When i pulled the HHO of and the engine stalled, i put back the HHO and pulled the cord.....
It blew up the bublers toplit and some of the glas broke as well. Big bang.Stupid wastspark didnt needed much time to ruine my 3 dollar bubbler.
Things i learned: Intake on bubler must be bigger then outlet bubler.
Use plastic jars.....doh....
did you do any mods to the engine other than the geet .
when you said it ran on hho only ,did you put a load on it ?was the rpm or the voltage the same ?
Thx
Najman
No other mods then the geet, Najman.
RPMs were like 3000. Volts on the meter of the generator where 230V
So, yes. A geet makes more rpms on same HHO.But dont tell anyone...lol
I plugged  the wfc into the powergen, but that story is for another time.
damnit that would have been my question. hho generated with the generator itself :D
but awesome results anyway, will it run without the motor oil?
Yes, it runs also without oil, haithair.
« Reply #57 on: September 24, 2009, 04:52:12 am »
Thanks to You stevie,,, Now I Truly Believe The geet works! So, you've confirmed it to work and i said i wouldn't believe it unless i seen you do it, And you've done it. So the geet is not a Myth!
But, Does the Geet Also work with Oil Vapor? What is the Geet Claim? Fill me in on that..
Now the Question is, what are you going to add to it. I will be keeping my eye on you!
« Reply #58 on: September 24, 2009, 10:50:03 am »
Yes,it seems to work with a film of oil around watervapours. I think i had too much oil in my bubler, yesterday.
Well, i need to make me a new bubler and try it again.
I also got advise to use a little bit salt in the water....
Of course you keep an eye on me. I dont expect anything less. ;)
« Reply #59 on: September 24, 2009, 12:38:30 pm »
Interesting stuff Steve!  :)
So:
50/50 oil & water did not work untill you added 2.5L/m HHO.
The genset runs on HHO alone.
You then made a mixture with much less oil and it worked on that.
Questions plz:
When you say it runs on 2.5L/m HHO alone; do you mean through the geet, or direct to the intake?
Did you bubble the HHO into the mixture of water/oil or just feed it in above the mixture?
What is the new ratio of oil/water salt that works without the bubbler?
What type of load is the genset able to pull on the different mixtures?  ie: how much power does it put out for each different mix?
Do you have different rod lengths for different fuels?
One must eventually start feeling like the slave of a whole lot of people you never met when the questions start coming thick and fast like this!?  :)
« Reply #60 on: September 24, 2009, 12:58:07 pm »
So:
Questions plz:
HHO went tru the geet.
If you do i after the geet, you need more HHO.
I bubled the HHO tru the the oil/water mix and i did a run without water/oil.
New ratio? I have to find that out...
I did my last tests with a 12 inch long rod which i used with petrol/water mix.
I als have a 2 inch rod here, which should work with water only.......but thats another test.
I first wanna run on used motor oil.
Then i ll go to the only water modus.
I dont feel like an answering machine. I just hope it starts a reaction by you guys to start build replications, so we can crack this quicker.
« Reply #61 on: September 24, 2009, 14:50:45 pm »
haha sorry, i used my crazy-free-energy-experiments-budget on the last device already :D
also not really a mechanic, but i hope to see more from you and from other replicators ! :)
« Last Edit: September 24, 2009, 15:06:26 pm by haithar »
« Reply #62 on: September 24, 2009, 23:58:34 pm »
Thx Steve (aka Answering machine!  ;D)
Very interesting about the HHO through the Geet.
As I understand you the there was no water or oil vapour going into the engine because the bubbler was empty at the time.
It means that the Geet is changing the H and/or O in some way.
Perhaps H2 is being split into Monoatomic H or something even more exotic!  Who knows!?
Does the oil, water, HHO mix add more power to the genset than straight HHO-Geet?
So decreasing the amount of oil enabled you to start the genset.
What ratio of oil to water would you guess you where using?
You have any info on the salt thing? why it works?
If you are going to experiment with old engine oil; perhaps tossing a magnet into the bubbler, to collect metal particles, will increase the life of the genset engine.
I got a 10HP engine thats almost brand new given to me because the carburator was missing.  :)
I have managed to get one lathe and the milling machine accessable...
I have no idea how to measure power from the engine though. (very important: there is a huge difference between running and doing usefull work!)
Hope that makes you and Dankie feel better!  ;D
« Reply #63 on: September 25, 2009, 09:22:57 am »
Logic,
That would be a nice project. Make a geet on the 10hp engine and feed it with whathever fuel.
The amount of HHO was less with the geet then without the geet.
At least the geet is making more volume of the gas and thats very needed with HHO.
And maybe the geet is also transforming the gas.
Dont forget that the wtarefuelcells are making steam as well. Nobody has only hydrogen and oxygen in the mix. All volts above 1.7 or so  makes steam. If the geet is transforming that steam into H and O, we gain.
