Hi warp yes I have seen all Stans work, I find that 'all is not shown' that is why I said it can not work in the configuration as shown in the patent. If you heat up water in an enclosed pipe to over 374deg C then exhaust it to a low pressure area via a 'suitable nozzle' that could be an expansion valve. you see to do this you have to maintain the pressure in the pipe so the the 'restrictor', nozel, or expansion valve, call it what you like, you have to keep the pressure of the water coming in at the same pressure with out letting in any 'air'this is done in some submarines it is a closed system, the nuclear reactor heat the water in an enclose space up to 400deg, C, the pipes that go though the reactor are also a closed system, it is the water in the later pipes that heat up the water to make steam, then that drives the turbines, and that is also a closed system. it is 'expanded' into steam directly into the turbine, the low presure steam is condenced back to water to be reheated. all this is done in the same way a refirgerator works.gee you got me going.The piont being this 'Oz Injector' can work 'under water' and so could replace the nuclear reactor.there are many other uses.well I have to stop.aussepom
@AlanI believe that the choke coils play the biggest part here. The two windings create a magnetic lag between each other...the magnetism fills up around the coil/core, and since amperage has a definite charge, it is affected by the fields.So, even though the conditions to arc over are reached...the choke coils hold back the majority of amps...so amps don't flow, yet the gas is ionized.
