Author Topic: Stan Meyer: What is high voltage in the hydrogen and oxygen generator  (Read 21997 times)
Patentnr.: 4798661
What is high voltage accoording to Stan Meyer.
In this patent he names everything above 2V high voltage!
In the voltage schematic, Stan showed different levels:
L1 = 2volt
L2 = 4volt
L3 = 6volt
L4 = 8volt
L5 = 10volt
L6 = 12volt
Ln = ?
He is reducing amp flow by way of limiting the time that the plates get their voltage and amp. A pulsating system.
The reason for doing that is accoording to Stan, that he doesnt want the voltage to drop, as soon as amps kick in and a dead short condition comes up........
What do you people think of this.
Re: Stan Meyer: What is high voltage in the hydrogen and oxygen generator
« Reply #1 on: April 25, 2009, 10:48:07 am »
Then Stan continues:
He uses the blocking diode for some purposes:
It must eliminate:
1. stray electrons
2. shorts
3. variances,
4. spurious signals
5. BLOCKING BEMF or back-electromagnetic force
« Reply #2 on: April 25, 2009, 11:00:26 am »
He continues:
The advantages of raising the amplitude of the pulses accoording to raising production og hydrogen:
The dual pulse system bring the upper limite to 5.5V or L3 in the schematic of figure 8.
Next step
The Stan is doing someting strange. Instead of connecting all plates or tube in parallel, he just switches between every plate of tube, so that one 1 is connected at the time. This would bring the upper voltage limite to 7Volts
See attachements
« Reply #3 on: April 25, 2009, 11:16:30 am »
The next level:
Hooking up a resistor in line with the negative tube.
This will raise the limite of voltage to 8.5Volts.
The resistor will block electron flow, which sounds ok to me.
Then he states that the voltage over the tubes is not effected by this resistor....hmmmmmmm not sure on that.
Then he states: In the generation of the hydrogen and oxygen gasses to an INFINITE limit, as yet not fully appriciated???? , the upper level of amplitude of the voltage is removed with utilization of the electron inhibitor (resisitor) of fig. 7, which is a sandwich resistor.
Yes, this is a big question.
I heard Stan says in a video the wfc operates on 0 - 2000 Volts,
I have also read that you need at least 1500 Volts to start the molecular ringing.
Kilovolt and milliamp pulses with twenty thousand cycles across the excitors is said to shake the molecules apart.
The alternator could have been used as a "hertz machine" and combined with a pulse circuit  it may reach 20.000 Hz
He says he is doing the exactly opposite of the electrolysis prosess.
Maybe he was taking OUT electrones so the water molecule collapsed?..
« Last Edit: May 01, 2009, 20:46:40 pm by WaytoGo »
He says he is doing the exactly opposite of the electrolysis proses.
Maybe he was taking OUT electrons so the water molecule collapsed?..
Thats an interesting question. How to extract electrons from water, without the molecules being aligned?
For sure, there is always an potential of voltage in water, but the current is pretty low.
The hydrogen atoms are always swapping oxygen atoms, so electrons must be floating as well time from time.
So, a pulsing circuit with an electron consuming device attached to electrodes would do the job, i ll guess.
Anybody any suggestions?
Does the EEC have a diode , I dont remember ...
The electrons were taken out of h2o but not extracted from the wfc, it contributes to further dissociation by colliding with other h2o and / or forming h2 and o2. I think this can be called ionization by collision.
If I remember correctly, in the NZ lecture he said an EEC on the wfc was not recommended.
The free floating electrons are used to create o2 and h2 from the single atoms, and to dissociate h2o like regular electrolysis:
The liberated and moving atoms (having missing electrons) regain or capture the free floating
electrons
once applied voltage is switched-off during pulsing operations.
Subjecting or exposing the water molecule to even higher voltage levels causes the liberated atoms to
go into a "state" of gas ionization.
Each liberated atom taking-on its own "net" electrical charge.
The ionized atoms along with free floating negative charged electrons are, now, deflected (pulsing electrical
voltage fields of opposite polarity) through the  Electrical Polarization Process … imparting or
superimposing a second physical-force (particle-impact) unto the electrically charged water bath. (electrolysis by reaction of e- with h2o)
Oscillation (back and forth movement) of electrically charged particles by way of voltage deflection is
hereinafter called "Resonant Action", as illustrated in Figure (1-10).
Applied together, electrical forces (TT') and (UU'), now, causes these moving electrically charged particles to
superimpose a physical impact unto electrical polarization process (160), as shown in (170) of Figure (3-
25) ... thereby, increasing gas-yield (88) still further.
