Stanley Meyer => Stanley Meyer => Topic started by: outlawstc on February 27, 2009, 21:10:05 pm
Title: The most important quote stan meyer ever made.
Post by: Login to see usernames on February 27, 2009, 21:10:05 pm
page 164, first page of voltage wave guide
""In each and all "Space State" of changes,
the combustible gas atoms of water is/are "Electrically Stress" under "different" pressure levels to bring-on the triggering point of thermally igniting the combustible gases of water beyond or away from "Stable State" of Equilibrium. Voltage Tickling of State Space under "Resonant Electrical Stress" without amp influxing while "Tuning-ln" to the dielectric properties of water is herein referred to as""
        "Resonant Action."
******************************************************NOTES*************************************************
each and all space state changes.------. dynamic(kinetic)  and static voltage.
electrically stressed under "DIFFERENT"  presure levels
"RESONANT ELECTRICAL STRESS"  the combination of static and dynamic.
outlawstc
ps
lets show them zombies whats up, smoke a bowl and get a higher perspective or drink beer get lower perspective.. hmmm who's fucking who? weed illegal---- beer legal hmmmm
i think im gonna get high!!!!!! lol
Title: Re: The most important quote stan meyer ever made.
Post by: Login to see usernames on March 01, 2009, 19:55:09 pm
I don't understand
Isn't the 'voltage tickling' causing resonant electrical stress?
or is 'voltage tickling' happening above Q, and RES happens when Q is lowest (but not 0V)?
See 8-2
Post by: Login to see usernames on March 01, 2009, 20:40:08 pm
resonant electrical stress is the term he uses for the use of both dynamic and static voltage input.. pure dc pulse of equal potential is a static pulse.. a unipolar pulse is dynamic.. combine them in a repeating sequence you get resonant electrical stress. since the chokes build up with there own potenial when it acts like ac but its not the same as ac.. ac is a push pull system from on side.. involving electron movement being forced on one side the neutral minus well be called ground in ac electric. understand that dynamic is a hole other force then static..
Post by: Login to see usernames on March 02, 2009, 16:30:05 pm
But what is voltage tickling?
voltage stress on state space without the wave fields 'overlapping' (as seen in 8-1), while switching between the voltage arc and ground state (=set by Q,  voltage arc 'travels' on it)?
the voltage arcs are the colored parts of the waves you've drawn in your latest pic.
