Projects by members => Projects by members => Pulsed => Topic started by: Pulsed on October 15, 2008, 20:35:40 pm
Title: The Water Fuel Injector: How he ran his car on water...
Post by: Login to see usernames on October 15, 2008, 20:35:40 pm
Good day gentlemen,
I apologise if this post is misplaced, as I am unfamiliar with the forum layout.
With regards to how Stan Meyers ran his Dune Buggy on water.
What has become clear from patent studies is that Stan ran his engine on energised and destabilised Thermal Explosive Energy from the water molecule.
He did not use a hydrogen generator to power his car, but rather used a steam resonator to resonate the steam using laser energy. Wherein the steam, generated by a boiler, is energised by means of laser light injection…
The Water Fuel Injector is a modified fuel injector, changed to have one metal rod in the centre of an outer metal tube and connected to opposite voltage potential charges.
There the steam flows in between the voltage field where the Ionisation process takes place.
The circuit to the Water Fuel Injector consists of:
-) A 120w power supply
-) A frequency generator capable of 10khz fitted with a power MOS-FET.
-) A High voltage resonant Transformer capable of 10kv at least
-) The Electron Extraction Circuit (EEC).
The Electron Extraction Circuit consumes the electrons that are ionised in the steam resonator with an amp-consuming device.
With out the EEC the process cannot be sustained.
Prior to this the Steam flows through the Laser Energy Injector, There the steam is energised by Laser diodes of the exact nm wavelength to that of hydrogen. This causes the electrons to move to a higher orbital state I CALL IT THE STEAM RESONATOR, priming the molecule for ionisation.
The burn rate control for the Ioniser is normal air to lower the higher burn rate of the Thermal Explosive Energy to that of natural gas.
This is how; weight for weight, the water molecule is far more powerful then oil.
All that is needed to run a car on water,
Please note this is not assumed from actual test results, which are currently under way, but from patent examinations.
Plasma.
This forum is doing good work.
Comments:
Title: Re: The Water Fuel Injector: How he ran his car on water...
Post by: Login to see usernames on October 15, 2008, 20:43:31 pm
Thanks Plasma, and im glad you finaly made it to the forum! Currently i can use under 1 amp at about 120 volts to super heat water into steam gas in under just a few seconds. I would say, "wild guess" the steamer consumes up about a gallon of water every few min's.
Do you have any data on the steam?
Thanks, Br Brian.
Post by: Login to see usernames on October 15, 2008, 20:57:34 pm
Hi to all
Can you Hydrocars please post schematic of steamer that your using
All the best
Post by: Login to see usernames on October 15, 2008, 21:12:28 pm
ONCE AGAIN.....HAVE YOU READ THE TECHNICAL BRIEF??
pulsed please please please re choose your wording or better understand what you are saying.....
THE STEAM RESONATOR HAS NOTHING TO DO WITH THE WATER FUEL INJECTOR AT ALL.....
it is simply used to keep the water warm from freezing and was only an added benefit for people living in colder areas where water for freeze.....THIS IS FROM STANS MOUTH......sooo please please please READ AND LEARN BEFORE MAKING ASSUMPTIONS.
some of what you say is correct
but you are mixing and blending things which overall are not what happened in the process you have some things spot on and are missing other important key factors......so please don't make a topic stating HOW HE RAN HIS CAR ON WATER.....if in fact you yourself are not completely aware of how he did it.......just read the technical brief one more time to make things clearer.....the atoms are NOT IONIZED IN THE STEAM RESONATOR.......they are ionized in the air processor or air ionizer......the burn rate is not controled by the air ionizer.....the air ionizer is a simple way of making oxygen highly more energetic and attacking the hydrogen atom which does increase the energy output and the burn rate of the hydrogen BUT THE BURN RATE IS CONTROLLED BY THE AMOUNT OF NON COMBUSTIBLE GASES IN BETTWEEN THE MOLECULES......ambient air gases such as argon........
look throughout this forum.......everything is here for the taking with lovely pictures.
Post by: Login to see usernames on October 15, 2008, 21:25:15 pm
Pulsed is our guest here. Please be nice to him. Hydrocars and I know him for a very long time now.
Post by: Login to see usernames on October 15, 2008, 21:30:33 pm
I will not put up with any negative post on this thread, "I have invited pulsed here serveral times", "We all at one time worked into private groups not known to your knowledge." I chose to remove myself from these places.
Pulsed is a ring leader, you do not know what he speaks of comes from group efforts that they spend many hours together on in secret places.
We will not have our guest treated in this manner.
That Simple!!! Think before you post!
This is not gonna happen here!
Pulsed, my apologies to you, please continue.
Post by: Login to see usernames on October 15, 2008, 21:36:31 pm
Pulsed,
Very glad to have you here at IonizationX.  Please post a lot.
Post by: Login to see usernames on October 15, 2008, 21:37:20 pm
Dankie,
You can write all you want here. No problem. But say it on a civilized way, please.
I do NOT tolerate anymore any rudeness here on this forum.
Post by: Login to see usernames on October 16, 2008, 01:25:25 am
Pulsed,
Very cool looking circuit.  Thanks for letting us see it.
It is very very exciting to have you with us.
Please let us here much more from you about this system of yours.  Thank you very much!!
You have great knowledge and we all want to learn from you.  We are your students.
Best Regards,
Fiditti
Post by: Login to see usernames on October 16, 2008, 14:02:32 pm
Oh my please dont say that! ;)
We are all students of Meyers.
Here are some pictures of my replication of the steam generator...
Picture one is the range of items I am using.
Picture two is the Ioniser itself, real life version of the picture in the 6th post.
Picture three is how it is all fitted together.
At this moment in time I have not built WHAT I CALL THE STEAM RESONATOR (laser injector) because this is not the crux of the system.
the EEC too is not built yet and I am awaiting many parts.
once again I appologise.
You have nothing to be apologizing for. I apologize to you my friend.
Pulsed, what happened to the circuit i had drawn? It does look as if one of the diodes are improperly inserted on the filament. I cant stress this enough, look at how the primary of the auto ignition coil is wrapped, and why its called a condenser and not a capacitor. I've explained this to many users on msn as well but it took me much time. We have step by step videos here showing a coil being unwrapped.
You're making Great progress in what you're doing. I Feel that what you're doing should be done by someone. I agree that steam is a gas vapor thats very vulnerable, I also think it is part gas in some way, that it just needs the proper methods to extract like your researching now. I do thank you for letting us know what you're doing, "it looks amazing so far." About a week ago i was experimenting with steam also, i just don't have the time right now to setup lasers and build a system for condensing the steam, "i felt as if it was reforming as it exited the water." However i did catch it into a 2 liter bottle to have it collapse a short while later, that was neat. Yes, ionizing these atoms by giving the a polarity charge and extracting the electrons could leed to success. I have also learned that no flame can be sustained into this gas, it was my intentions to cool it then retry and note the effect. At that time i was determined to catch this gas and alter it. However i have other things that has to get assembled.
Unfortanitaly I now have this dune buggy engine i have to put together. Today i installed the crank and painted the housing. This will be my 3rd time of putting it together. I still recommend you to look at the post i referred you to, The coil in that circuit is very important to understand because the way it restricts amps on charge and increases voltage on discharge. Gotus used this same coil to violently ignite water. I look to update and use it on my buggy. I am glad to see that you haven't given up. Maybe soon i will be able to continue the vapor test as i feel it is coming.
Post by: Login to see usernames on October 16, 2008, 16:13:41 pm
Hi Plasma,
That was me that metioned my experience with ionizing steam.
Welcome to this great forum.
Post by: Login to see usernames on October 17, 2008, 08:29:27 am
I am in healthy contact with electrojolt, he is one of a kind.
Post by: Login to see usernames on October 17, 2008, 18:15:21 pm
Thank you pulsed for explaining your thoughts on Stans work!
Is there any practical example of your work that you can share here?
Post by: Login to see usernames on October 18, 2008, 02:37:01 am
Pulsed,
We are so happy to have you here.  Please keep your great information comming to us.  Thank You so much!!
Post by: Login to see usernames on October 18, 2008, 05:51:11 am
Pulsed,
Don't mind Dankie.. he means well, he just has poor choice of words sometimes.
but it is all good.
Post by: Login to see usernames on October 18, 2008, 21:32:46 pm
Lol it looks pretty complex...
What did you think of the patent i suggested ?
Post by: Login to see usernames on October 20, 2008, 19:12:58 pm
Why do Dankie's posts keep disappearing???
Pulsed,
Pulsed Dankie is working on Improving his respect for others, He may come across the wrong way sometimes. There's nothing wrong with debating but just do it nicely as we love all of our members here, every last one of you guy's, fight with respect.
There's always an possibility he didn't know his post was negative or harsh, We do not remove post here without cause as it would be disrespectful to our members here if we did.
If there's a post missing then there was something wrong with it, Just ignore it,. If it was your post that got removed do not get angry. If we didn't value our negative members then we wouldn't be doing what we're doing but giving them a big boot. So obviously we care about our members here as well as manners.
I am hoping this technology will go threw an attitude change, where conversations will start to get more "civilized".
Can you understand what i am trying to say here pulsed?
Br, Hydro
Post by: Login to see usernames on October 22, 2008, 23:19:51 pm
very good, pulsed!
Nice drawing too.
Post by: Login to see usernames on October 23, 2008, 00:17:29 am
seriously that is a great drawing.....i love the light reflections.
Post by: Login to see usernames on October 23, 2008, 04:30:09 am
gr8 drawing pulsed ,but could u pls write down or label the parts this would help me and others also who have very little knowledge abt the cell
rgds paul
Post by: Login to see usernames on October 23, 2008, 14:19:33 pm
Pulsed,
Thank you very much.  This last post helped me a lot.
Post by: Login to see usernames on October 23, 2008, 15:25:15 pm
This technology is simple.
Let's all hope so. Can't wait for your results.
Post by: Login to see usernames on October 23, 2008, 17:41:16 pm
gr8 work pulsed,its just what i think will give all of us some idea as to what ur doing gr8
hope to see more news from u abt  the working of all ur components,when will u let us know,
we all know u will help
gr8 ,we can count on u
ty for the dia.
rgds paul
Post by: Login to see usernames on October 23, 2008, 21:33:40 pm
wow this is gret but just one point to point out....for the electron extraction circuit to work i'm pretty sure the light bulb must not be on the ground wires......electrons are attracted to positive fields....your light bulb should be after your chokes on the positive end.......and for the flyback transformer i have 3 of these things and have believed that this could be used in conjunction with the bifilar coils to work seeing that they have a very high resistance.....but i can't locate the pins!!! i have tried what naudin does to locate pins on flybacks but nothing works!!!! argh! I CAN'T WAIT TO SEE YOU NEXT STEP I LOVE THIS!
here is a simple photo of the amp consuming device.
(http://i2.photobucket.com/albums/y2/kinesisfilms/ampconsuming.jpg)
Post by: Login to see usernames on October 23, 2008, 22:01:50 pm
here this is a much better example...see how the amp consuming device is placed on the postive connection......on your setup the inside is positive while the housing is negative....meyers had this reversed and i guess that could have led to confusion when you hooked it up.
(http://i2.photobucket.com/albums/y2/kinesisfilms/ampconsumingbest.jpg)
Post by: Login to see usernames on October 23, 2008, 22:10:00 pm
and one last good photo
(http://i2.photobucket.com/albums/y2/kinesisfilms/amppositive.jpg)
Post by: Login to see usernames on October 25, 2008, 19:02:24 pm
Why are you using the outside as negative, while stan draws in the tech brief the inner tube as negative?
Post by: Login to see usernames on November 11, 2008, 02:05:15 am
http://uk.youtube.com/watch?v=YYNkBKJPK4I
Post by: Login to see usernames on November 11, 2008, 10:40:23 am
Impressive vids of Chris. As far as i understand the plasma systems, is that it is rather difficult to get a stable spark and that the electrodes are consumed on a very fast way.
Post by: Login to see usernames on December 08, 2009, 17:28:34 pm
Lol, thank you.
Ok.
First we look at point No.1:
I am using two plug main power inputs, one for the boiler and one to power the Ioniser.
Point No.2:
This is a power supply I have, it is DC 13.5v @ 6 amps, so it is an 80 watt power supply. There is no pulsed frequency in the output voltage; it is at the moment fitted with a 1A fuse.
Point No3:
This is the Frequency Generator that I have built, it is the circuit by Mr Lawton, his theories don’t apply, I am using the Frequency Generator differently, and there are some major modifications.
The Frequency Generator supplies a stable frequency that is adjustable and gate enabled.
Point No.4:
This is the Flyback transformer supplying 50kv to the High Frequency Inductors.
It is resonant but will not be driven in a resonant state, so the output voltage will be cut indefinitely.
It has a Ferrite core, and is a miniature Tesla Coil.
Point No.5:
These are the two large Blocking Diodes that keep the circuit running on Direct Currant allowing it to charge and resonate with the capacitor, or Water Fuel Injector.
Point No.6:
This is the Electron Extractor, in place to consume the electrons dislodged by the Ionisation process. This stops the Electrons stabilising the water molecule again.
Point No.7:
These are the High Frequency Inductors, They are wound on a ferrite core, the wire is 0.35mm and there are 500-1000 winds on each core.
The purpose of which is to restrict amperage from getting to the Injector and water molecule.
Conventional electrolysis uses electrons to feed into the water bath. We are restricting those amperes or electrons so that we can – Destabilise, Energise and Ionise the Water Molecule.
They accomplish this by a simple RF Schoolbook process.
‘When a High frequency charge of electricity meets a large inductor, the amps are “Choked” but the voltage continues’. This, too, causes RLC resonance to take place causing voltages “beyond applied voltage level”, thus generating the voltages necessary to sustain the Ionisation process.
Point No.8:
This is the boiler, I have striped the hating element from a normal kettle and housed it in a SS cylinder that holds a relatively small amount of water, there the Heater is turned on to generate steam to thus be turned into Thermal Explosive Energy.
Point No. 9:
That is just the pipe that carries the Steam to the Ioniser.
Point No. 10:
I will go into the construction of it in greater detail later, but that is the Ioniser Itself, it just screws onto the tube that feeds the Steam to it.
As of not I will not build the Laser Injector as I feel this is not Paramount to the process,,,
This is an important piece of work. Where are you with this project? The setup is similar to a fluorescent tube or neon tube, the gas in this case is the steam. I believe this is where the high voltage is applicable and not the liquid water.
Post by: Login to see usernames on December 10, 2009, 01:41:46 am
http://www.google.com/patents/about?id=iCp7AAAAEBAJ&dq=7125480+b2 (http://www.google.com/patents/about?id=iCp7AAAAEBAJ&dq=7125480+b2)
http://www.google.com/patents/about?id=OBPJAAAAEBAJ&dq=7125480+b2 (http://www.google.com/patents/about?id=OBPJAAAAEBAJ&dq=7125480+b2)
A thermos flask comes to mind if you are looking for a reflective container to but a UV bulb in.
Commercially available UV Water purifiers come in reflective tubes.
