Stanley Meyer => Stanley Meyer => Stanley Meyer => Topic started by: HMS-776 on September 20, 2008, 05:06:48 am
Good points you raise HMS. Would it help then to add electrolyte to the water to reduce it's dielectric constant?
I have also noticed that the dielectric constant is inversely proportional to the strength.
Don't waste your time with PVC, Super corona dope is better. I have tried both.
I finally got my LCR meter the other day, measured my 3" tube set and came up with 3.9uF bare.
As stan states in his patent with 3" tube sets he hit resonance at 10kHz,
If 10kHz was his pump frequency, then his resonant frequency was 5kHz
The size of his inductance to have a resonant freq of 5kHz would be about .25 mH which would be some timy chokes.
If built on a 1" diameter air core 5" in length with 24 gauge wire you would only have 235 turns and a little over 1 ohm resistance.
This means that at least in this patent the tubes were most likely not insulated.
The bifilar he had in the International independant report looked big , a few thousand feet at least , they were not tiny at all .
wait what?...what's a thousand feet?
In his patent he mentions 100 turns each which works out to really close to what I calculated above.
I think I'm going to insulate min though!
Without insulating I see many problems, mainly a huge voltage drop in the WFC since it would be dead shorted!
A huge voltage drop is what you are hoping for lol... the purer the water the better , thats why you are adding a coating.
He mentions that in his patent true , he mentions that his *electrical polarization* process could be *verfied* using a toroid and 100 turn coils but do you seriously think the process ends there with that very basic design and thats his actual water fuel cell?
