Stanley Meyer => Stanley Meyer => Stan meyers resonance => Topic started by: Steve on July 10, 2008, 11:04:13 am
Title: What did Stan meyer really said.......
Post by: Login to see usernames on July 10, 2008, 11:04:13 am
Stanley Meyers:
The Hydrogen Fracturing Process dissociates the water molecule
by way of voltage stimulation, ionizes the combustible gases by
electron ejection and, then, prevents the formation of the water
molecule during thermal gas ignition ... releasing thermal
explosive energy beyond "normal" gas burning levels under
control state ... and the atomic energy process is environmentally
safe.
Title: Re: Stan Meyers, the basics
Post by: Login to see usernames on July 10, 2008, 11:06:39 am
Water now becomes part of the Voltage Intensifier Circuit in the form of "resistance" between electrical ground and pulsefrequency
positive-potential ... helping to prevent electron flow within the pulsing circuit
Post by: Login to see usernames on July 10, 2008, 12:56:00 pm
Stanley Meyers:
A fancy word for electrolysis, Stan Bettered the electrolysis process with his tuned cell, but in no way did he produce 7 liters a min but around 700 cc's per min.
electron ejection
Another Fancy way to say he ionized the gas, he uses hundreds of expressions, cant believe resonance isn't in there.
Thermal means very HOT, laser heated to ignite gas, no fire no water formation.
safe.
"(Laser Ignition,thermal")  and ("Laser photon injection,Change of energy state") Prevents reformation of water and controls the "(2H protons energy level,2h contains neutrons")  via electronic photon injection.
Post by: Login to see usernames on July 10, 2008, 23:11:43 pm
The established resonant frequency is most generally in the audio range from 1 Khz up to and beyond 10 KIlz; and is dependent upon the amount of contaminants in natural water. Oscillating and superimposing electrical charged particles unto the Electrical Polarization process at a given pulse-frequency is, now, herein called "Resonant Action", as illustrated in (240) of Figure (3-25).
To reach maximum gas-yield (88) resonant cavity (170) of Figure (3-25) is shaped into a tubular structure (typically 0.50 inch diameter tube inserted into 0.75 inch diameter tube having a .0625 concentric air-gap 3 inches long) which functions as a longitudinal wave-guide  to enhance particle movement in a lateral or angular displacement to applied voltage fields (66/67). Insulatedhousing (72) prevents voltage coupling to water bath (68) which allows applied voltage amplitude (xxxVn) to remain constant across water molecules...
My explanation: when you use the Stan Meyer circuit, use frequencys between 1khz till 10khz
Use a bifilair coil of 100 wraps for each coil (totall 200)
Use a tubes of 3 inch high T304 0.5 inner and 0.75 outer tube with gap of 0.0625
Insulate the outer tube with delrin or similair
Insulate the inside of the innertube.
Use a nice pulsing circuit.
I can confirm to you that you can get a step-up charging effect with this.
Post by: Login to see usernames on July 10, 2008, 23:54:57 pm
about  a longitudinal wave-guide:
1.
sound waves are called longitudinal waves. They need a medium through which they are propagated.
This can be proved by enclosing an electric bell into a glass jar. When air is present in the glass jar, the sound of the bell ringing could be heard but when air is pumped out of it the sound of the bell ringing is no longer heard although one can still see the bell being struck by the hammer. Note that since sound needs a medium through which it can be transmitted, then the denser the medium, the better the transmission of sound.
One notes that longitudinal waves consist of successive compressions and rarefactions in the spacing of the medium which is carrying the wave. Therefore now it should make more sense as to why the denser the medium is, the better it becomes at transmitting longitudinal waves.
The speed of sound in air is about 330m/s at 00C and increases at higher temperatures. In denser mediums than air, for example steel, the speed of sound can be as large as 6000m/s.
go read on part 2
Post by: Login to see usernames on July 11, 2008, 00:18:32 am
part 2
The speed of waves can be calculated by using the equation shown below:
C = f  . ?
where: c = speed of the wave in m/s.
f = frequency in Hz (/s).
? = wavelength in m
Put that into the tubes of Stan: 3 inches are 0.0762m and use the speed of sound into steel, like 6000m/s
We should get a frequency out of this:
6000 = 0.0762 . 78740hz
Now this speed in steel is i think not the right one.
I found this: Steel, 347 stainless, velocity of longitudinal wave (extensional wave) in thin rod = 5000
5000 = 0.0762 . 65616hz
Riddler this is for you: 5000m/s = (10.5 inch) 0.27m . 18518hz
for sofar this part
Title: Re: What did Stan meyer really say.......
Post by: Login to see usernames on July 12, 2008, 11:20:51 am
The resonant cavity of Stan Meyer in practice.
Please have a goooooooooooooood look at this picture and think what happens in this cavity when it is filled with water and you have power on it......
Please reply this this question. I wanna teach you all here something, if you wanna know how Stan got resonance....
Post by: Login to see usernames on July 12, 2008, 19:54:50 pm
I think a lot of us inlcuding members on this forum have achieved 500 to 1 LPM gas prdouction (regardless of power consumed) but no one seems to have got an engine idling on it.
I dont know if stan produced  7LPM as per his claim but he is definetely producing way more than 700cc in this video.
http://www.youtube.com/watch?v=EKmB6-wZSh8
He actually states that he is holding 13 3/4 pressure, which is the maximum the pressure gauge on his cell goes. The same cell that is on  the video it runs on water. That cell is definetely producing way over 700cc.
So he is holding max pressure of 13 psi and then idling his dunebuggy. Riddler I dont know how much gas one can slowly release and hold 13psi pressure for given 700cc production but there is no way that small amount of gas can idle a dune buggy.
If it is possible to hold 13 psi pressure and continously burn even a needle flame I would like to see anyone make a video and prove that its possible. the pressure has to be constant though while the flame is burning or bubbled up using a bubbler.
Title: Re: What did Stan meyer really said.......
Post by: Login to see usernames on July 13, 2008, 00:44:50 am
Trust the Riddler, watwerfalcon.
Post by: Login to see usernames on July 13, 2008, 21:29:25 pm
did anyone catch what stan's amps was, i could hear him say 5 volts and 13 3/4 psi but couldn't hear the amps.
if he was pulling minus 13 3/4 psi he would have a 93.5% vacuum.
james
How did Stanley get the hydrogen into his engine if the cell was under vacum?.. ;D
Post by: Login to see usernames on July 14, 2008, 11:14:08 am
Stan used 40 amps. :)
But
Stan used many different setups.........
Title: WaterFalcon
Post by: Login to see usernames on July 15, 2008, 05:24:12 am
WaterFalcon
Post by: Login to see usernames on July 15, 2008, 05:29:39 am
did no one catch how many amps he said ?
james
stan used 5 volts 2 amps to the rotor, roughly 35 to 40 to his cell... Oh, and the psi was 13 3/4 before he ran it into the glass display box on his buggy, the one that contained the Electrical Polarization Generator (EPG) or what i like to call the ionizer. .
Post by: Login to see usernames on July 15, 2008, 05:33:37 am
Riddler
I was kind of expecting the video. ;D
If not, I was going to try to make one.
Spike
Post by: Login to see usernames on July 15, 2008, 07:04:22 am
Thanks riddler for the video. I now believe this is exactly how stan impressed all those clowns over the years with this simple little trick. No wonder he didnt allow any one to inspect his WFC further cause it was just regular electrolysis.
crap its sort of a bummer now that I know for a fact stan never reached OU. Beginning to wonder if the rest of stans stuff was BS too. For all we know the EPG could have been a gas tank? Wonder if it just  a matter of heating the HHO to enhance it to orthohydrogen or which ever the one is that is more explosive than regular hydrogen to idle the dune buggy at 600cc per minute.
Riddler in the video...What was the amp draw to your cell and CC per minute?
thanks again for your efforts in making the video to clear my doubts. Highly appreciated.
Post by: Login to see usernames on July 15, 2008, 09:05:04 am
I have never tested the production of this cell however my last cell used the same container. So im guessing right at or over 500 cc's a min, i feel thats a close guess for now. i've only had this cell together for about 2 days now.
About heating the gas, i have ran several test on this, 3 to be exact. Relaxation was my first test it worked very well! Heat was my second test, its temp sensitive and not worth the hassle at all, to hot and the hydroxy dies. The third test was ionization which was the most easiest to do. The engine spuddered threw all 3 test, but the ionization promised more than the others. I seen that the engine could idel with more gas, im pretty sure around 700 cc's would idel it by way of ionization based on what i seen, and i think if you seen what i did youd think the same!
After i added the bubbler to my cell i failed to replicate my own work of the ionization process, i think this is due to the bubbler and pressure hoses. I'm using a bigger fatter hose then i was before and im getting bloops and not a steady flow, bloops break the connections in the gas so im not doing to great on that right now. it's important that i find a very small hose since im using a bubbler, i need a steady flow for this to work no bloops in the line.
To see that engine run on ionized gas was cool, it sounded like a diesel! i built the pressure up and cut the alternator off, slowly released the gas threw the bug zapper and i could hear the engine running on hydroxy as long as the psi gauge droped a fair bit, but it wasn't to bad.I cant run the alternator and driver motor for the engine or i'll trip a breaker..  It sounded week but was running with the starter motor, this is why i believe laser injection will make the gas less like diesel and more like gasoline, stan used it.  Stan could have ionized his gas better than i did that day, he could have been producing more than i was, or he may be like you said, a damn liar.
who knows?
I am near my last steps in determining if this is a hoax, or possible, stan was smart and its possible i may drop out rather than dedicating my entire life to figuring it out, its really hard when your the only one that can perform the test to both rule in and out what is and what is not possible based on the data that is available to us,, and lately its been a drag... So my cell is built and im kicking back and maybe taking my time on finding the hose that will give me the proper pressure due to the problems in pressure the bubbler causes. I know what i seen when i ionized the gas both with my eyes and ears when the engine somewhat ran on such low amounts of gas.
it would be  a dream to see someone take this further,, such a slow moving progress..
Post by: Login to see usernames on July 18, 2008, 12:11:15 pm
I meant that if you use a chamber like Stan showed in his technotes, you will get the following thing happening
The thing is that his cavity  has a small opening on the bottum and top.
What will happen is that the chamber first, is fllled with water. After starting up, it will be soon a 90% of bubbles.
Bubbles do not conduct.
Amps are restricted.
That was my found theory...
Bubbles still do not conduct.....but i couldnt get the amps down as far i wished for. I tried that cavity.
So, yes, the content between the plates changes from water to gassoup with at the bottum a low level of water....
Post by: Login to see usernames on July 21, 2008, 19:30:29 pm
What ? Stanley Meyer secrets?????!!!
 http://www.more-per-gallon.com/Meyers-Secrets.pdf
Kind Regards
Post by: Login to see usernames on July 22, 2008, 09:36:25 am
Can`t find the 1200 v ac inverter anywhere he mentioned, can it be 1200 w he ment?..
Kind Regards
Alvas
Hi Alvas
I know the whole Tad and ted storys.
I happen to have 2 such a neon setups..actually 3, but i blew one up.
The question to solve in that case is if one ofr both tubes are insulated.
Secondly, if the tubes where not insulated, what the capacitance would be of the cell.
Post by: Login to see usernames on July 26, 2008, 21:51:46 pm
who knows?
Can you tell me what engine you were testing your cell with. Meaning single cylinder, 4 cylinder 6, 8?  Was it a car or a portable generator?
thanks hydrocars
