Projects by members => Projects by members => Hydrocars => Topic started by: Hydrocars on October 04, 2019, 01:23:00 am
I have Instructions STEP BY STEP how the Vic works. The Instructions was written By Stan Meyer Himself!
I have a Parts List that goes with stans Instructions, Written Also by Stan Himself!
I have been filling this order, and also, I have covered all the areas that everyone has missed using all of stans instructions.
This Technology is very real! It has become very clear stan was not a fraud after what all I have found. Stan uses a Polarazation Process to cause an electron depletion that causes the covalent bod to be broken. It is very clear that 20 thousand volts can easily be read directly across the Exciter Arrays when you use the Voltage Depletion Process. FurtherMore, A Lazer, or a Led will further increase the process in the water to gas version to increase the rate at which the polarization process takes effect.
Furthermore, the Electron Extraction Process Destroys the electron in the Gas causing it to become Thermal Explosive energy.
Furthermore, Stored Liquid Hydrogen containing atomic altered Atoms in one tank, and the same in the oxygen tank.
Furthermore, It is very clear Stan ran engines on water before the VIC was ever invented. It is also very clear stan used a method called the Airiator to aid.
YOU GUYS SHOULD UNDERSTAND, IT DOES NOT TAKE ANYWHERE NEAR 12 LITERS A MINUTE TO RUN A ENGINE ON WATER, YOU HAD IT IN THE PALM OF YOUR HANDS, YOU DIDN'T DIDNT KNOW WHAT YOU WAS DOING.
I HAVE ALL THE INSTRUCTIONS.
I do not want to do this alone, who wants to take this project on?
who wants to get this technology out there once and forall.
i want
can you send me by email ... sebosfato@gmail.com
12 L/m of gas is not so small quantity
55 amps gives 36 liters of hho that is around 0,51 liter per minute of gas would generate 2 grams of hydrogem per hour + 16g of oxygem 120 watts is fair enough for a good cell and feed circuit
it could be generated with 11 cells in series having 5 amps to flow...
12l/m would need around 1320 amps or 11 cells in series having 120 amps flow i guess 3kw would do it
you got my attention.. waiting for it!
me too
"In the early days Stan ran a Bolen tractor at the Hughes farm but Stan would need to run the tractor a while before
taking it out in the fields on the farm. Sometimes he didn't have enough to get back to the barn. He was using a
vessel with stainless tube in it." I don't believe he was using a VIC at this time but more likely brute hydrolysis
and storage of the gas at that time
Are you saying that you have an original parts list written by Stan or a instruction guide actually written by Stan
from lab notes or such? Or is this a guide written by you.......
It's all stans writing. I will update the forum asap. And yes, he ran engines from water before the Vic.
where did you put? asap? is in your project section?
Are you kidding me? You have info strait from Stan and you didnt share it, sofar?
I am not sure if i must be happy or very sad....
Today is saturday, i see no better time than now to share it ;D
anxious to see what your talking about.
Hydrocars are you sure about you are saying or just seeking for attention?
i found something interesting
water has a bandgap of 1.239volts if we convert this to wavelength it gives 1um
2.9959e+14 Hz
https://www2.chemistry.msu.edu/faculty/reusch/virttxtjml/cnvcalc.htm
I'm going to throw a very fast blunt video together before I leave out for the night, sorry to leave you all hanging.
https://youtu.be/YlcPBbN1jA8
Same old thing. Nothing new.
Don't waste your time.
This is from the tech brief nothing more.
We all or almost of us had this.
I don't understand why you think that you have something new...
Tou need to read more about the subject.
maybe was first time you read it? well we read it hundreds of times... end to end... whats new bro?
this is a mistypo transfonner?
nice circuits! compliments
If this is the attitude you guys are going to have, I simply will not update you anymore. I'm sorry you don't understand it. Stevie, we can continue this manger if you like, I am working on breaking down these formulas atm. My parts list has been filled and on the way. And by the way, I measured over 1 thousand volts across my cavity last night. You guys are unbelievable, I suggest reconsidering. I haven't shared 2hat Stan was doing with the gas either. That's another day.
I have had issues, With Low Viberations, I have had problems with entities.
I will break down this in my forum name under hydrcars, I will slowly do this, Sorry for snapping, But, I have been having issues lately, I've been sick. I've been dizzy.
This technology was used by tesla, and stan used it. I will start with the basics that even I myself Missed. Please Continue this under my forum category Hydrocars. I will have a post for each and every important part of this system which makes up its body. I do need help for thost that wishes to participate.
Also, for what its worth, I have already read over 1 thousand volts across the Exciter arrays. Also, Stan say 20 Thousand volts could be seen. Also, Sorry for the snapping. Hopefully if you follow my work, you want get sick to!
Also, I will be Continuing stans work as he left it off. I have not seen anyone even come close, even stan said even scientist fell flat on their face! I can see why!
Now I know The SCR was used for the EEC. I've seen stans pattern, I never knew he was this smart. Stan started out seperating the gas.
The Earliest steps, was, Stans AirIator was Invented Before the VIC was. The AirIator was A Gas Mixing Chamber. I will start another thread on that later, It is not important when 'l;daf;lkjas;f, Theres 2 things going on here, 1, producing HHO with no current flow, 2 Understanding that 1 gallon of water is equal to 2.5 Million Barrels of oil. You did not need the amount of hho you was producing to run that motercycle stevie, you had way more than you thought you needed. I will address this with you at a later time.
Yes you all have had this information, Yes, you all overlooked it. Including myself.
Brian,
I know that people doesnt understand the proces you are in.
But for what it is worth, i still stand with what i told you when we started this forum.
So, lets finish this technology of Meyer for once and for all.
Great work Brian,
The way I see it we can all benefit from the opinions and research of others, no need to put anyone down.
Perhaps he just realized something he didn't notice before, we've all been there...
Anyways, the thing I am wondering Brian is what are you seeing that others aren't?
Many of us have spent thousands of hours testing, troubleshooting, and tuning and have yet to hit resonance.
Stan states it is a simple series LC resonance, but if it really were just a series LC resonant circuit we would all have had it working years ago.
What are we missing here?
For some reason, I am seeing everything in stans work, and I am missing nothing. I dont know why.
Adriank, Have you used the Resistance Wire for the secondary, 36 awg, and chokes, 24 awg? Have you used the formulas in the work to confirm your circuit was in tune?
Did you isolate your ground? The Positive Pulse Attracts the oxygen water molecules electrons when the Voltage Field undergoes the Voltage step process, and the negative zone pushes it away. the Negative zone attracts the Positive Hydrogen proton. The Water Molecule has a equal charge, a Zero Net Charge.
It is not until the Exciter arrays are stimulated with the voltage process, and exposed to the Polarization process you will see this effect. The water molecule has to first Elongate caused by the (Pulse Train) in a step charging effect by use of the Transfonner stan calles the Voltage intensifier Circuit. It is only then the Molecule reaches a Critical State and the VIC causes a electron Depletion switching off the covalent bond. Furthermore, The Electron extraction Process Destroys the electron making it impossible for the hydrogen and oxygen atoms to recombine.
The Isolated Ground (J) Causes the Positive pulse from (C) which is a (frequency Modulator) to give Exiter arrary E1 a positive electrical Fiel so great it pulls away the negative electron from the water molecule. Without (J) this would not happen. This VIC is a Voltage (Progression) DEFLECTION Process.
(electronics)
The voltage applied between a pair of deflection electrodes to produce an electric field.
https://encyclopedia2.thefreedictionary.com/deflection+voltage#targetText=deflection%20voltage,to%20produce%20an%20electric%20field.
https://www.google.com/search?ei=ONuYXdrFAsv8tAXxm4TIBg&q=define+progressive+&oq=define+progressive+&gs_l=psy-ab.3..0l10.19945.21084..21891...0.2..0.118.650.5j2......0....1..gws-wiz.......0i71j33i160j33i10j0i22i30.SKwSqVyWhmo&ved=0ahUKEwjawY-42oXlAhVLPq0KHfENAWkQ4dUDCAs&uact=5 (Pulse Train)
Quick Examples https://duckduckgo.com/?q=air+ionizer+deflection+circuit&t=h_&iax=images&ia=images&iai=https%3A%2F%2Fimages-na.ssl-images-amazon.com%2Fimages%2FI%2F41jsmYkmHuL.jpg
https://duckduckgo.com/?q=air+ionizer+deflection+circuit&t=h_&iax=images&ia=images&iai=http%3A%2F%2Fwww.seekic.com%2Fuploadfile%2Fic-circuit%2F201357214617346.jpg
(C) is a Modulator in Figure 1.1 Once Positive Volatage Field Goes High, Blocking Diode (B) Only allows voltage to flow in one direction, Positive Voltage Field is Conneected threw Isolated ground (J) Causing a step charging Voltage Field across Exciter Arrarys ER1 and ER2 which causes the voltage deplection process. (Polarization Process)
about deflecting, its in Stans work clear that he applied a negative and positive puls to the electrodes.
Not a ground and a positive pulse.
A negative and a positive pulse. Coming out of the bifilar coil of the vic.
He needed strait dc electrolsys , i think as a start pulse, followed by the pulse from the bifcoil.
The voltage across the cell is zero, but thats because both sides compensate.
However, compared to neutral .....
I think that is what he ment by using acceleration.
https://www.falstad.com/circuit/
$ 1 0.000005 4.078577355933338 50 5 50
T 112 160 192 208 0 4 1 -0.00006420120755636316 9.402065827586223e-20 0.999
T 432 160 368 112 0 4 1 0.0000642012075563528 -2.2022832859098747e-20 0.999
v 432 160 432 208 0 1 40 5 0 3.141592653589793 0.5
v 112 160 112 208 0 1 40 5 0 0 0.5
d 192 160 240 112 2 default
p 240 112 240 208 1 0
p 320 112 304 208 1 0
w 288 208 304 208 0
w 240 208 256 208 0
w 192 208 240 208 0
w 368 208 304 208 0
w 256 208 288 208 0
d 368 160 320 112 2 default
o 6 64 0 4098 5 0.1 0 1
o 5 64 0 4098 5 0.1 0 1
I think I can insert a LC resonate Circuit Threw the AIR on the Positive Exciter Array, and do the Same on the Negative, I think I can Make A Wireless System to incorporate into Stans Hydrogen Fracturing Process.
You ask, what is new? Why am I just now coming forward ( Its because I just started To see what was going on)
I think their was a Block preventing me from seeing how it worked, it was recently, (Unblocked) from my brain. I see everything, Before I was Blind and could not see. Stans Instructions is Clearly there, Step By Step, Very Detailed instructions. It is all there! And it all makes perfect since. I do not think this technology stops at the water molecule, I think it goes much further, even to propel spacecraft from the ground up threw space without the use of water. I think the electron Deflection process can be used on much more than just water. It all dates back to around 1940s
This type of Voltage field generating apparatus is not used in todays generation. I think We, Us here at this forum as a team may very well crack much more than just electrolysis on its head. I think electrolysis by voltage deflection is just the start of the new aircraft that is yet to come ( Lifters) understood and Step Charged using a progressive attack. I think John hutchesin tuned into allot of this. This must have been how telsa ray gun worked, ( Hydrogen Gas Gun ) (Aircraft Lift Gun) Healing of Cancer, etc, I think this technology will open the doors to much greater solutions. Once it is understood and used, I think its power will be great!
you need to learn what a transfonner is, (dig a little deeper) Yes, its old, very old! No, Stan did not mistype this at all, because I've researched it years, and yes it is a Transfonner. It is a Secondary inductor attatched to a secondary circuit to allow a large range of Frequencies. It is a Voltage Deflection circuit for Exictor Arrays, (Dig) Stan was no Green thumb, He obviously knew his stuff! He was indeed a math matticion just as great as Nikolai Tesla.
I understand you bro, life is crazy and it sometimes makes us blind and sometimes good or bad.. i highly suggest for you if you already dont know it to take nitazoxanida this is a medicine to kill intestinal worms,.,, i have had this crazy worms for years and it was holding my energy and my will too. My doctor prescribed that everyone should take it at least once a year! to control their population inside of us!
I know how is it like to understand it clearly! keep going we are here to support you!
I never tried running engines on hho i will do it soon with my new cell i think it will have enough hydrogen to get started. hopefully =D
i did a google on that word but i only found some books that were scanned and so it appeared to me that the scanner mistyped.. i will look further .. you have any source?
I will attack you on this later, But for now, figure out how to seperate your hydrogen and oxygen, if you cant do that then re design your cell. Stan was doing this. Sorry for those that couldn't see it. I will prove this fact later! Till then, get it seperated. View the Airiator while you do this, the documents on it.
Yes, duckduck go, look for Tube type circuits, Look for what looks to be a VIC that has nothing to do with stan. Give me an hour and I will find you several similar circuits, Unfortanitly, I dont have the time today. I'm at a party.
For those that wants a promising but Flawed results with their fake chokes and un worthy copper coated wire do the following.
Attatch an antenna between your Diode and secondary transformer, alter freq, you will read Kilovolts.
That is only a fast example that will allow you to view high voltage directly across the cell. Important to know, Electrical Isolated Ground (J) should be adjacent from the diode. I just described a flawed methode to allow you to see a voltage across the fuel cell.
Also, 78 ohms, I used 2 inches tall with 1.5 Inch gap, 1.5 mm. More to come, Reasearch!
Find those Depflection Circuits, which is a Transfonner tuned to a Inductor. (VERY SORRY THIS INFORMATION IS GETTING LOST) and becoming obsolete.
Also, someone grab all of stans patens from the patents office website, I assume they will start to dissapear very quickly. Stevie, you do this. Post links to them here, upload them here before they are all gone. We need these here anyways. if you already have them, post the link here. SO that I can access them and further explain what he was doing to the gas.
This is my diode I received today.
Dear Hydrocars,
If you just look a bit futher then the lenght of your nose....
There is a whole chapter on Meyer in this forum.
http://www.ionizationx.com/index.php?board=195.0
If you think i missed out on a document, then please let me know.
Good deal Steve! My monkey boy is trying to break out if his baby jail, hard to do anything this day in time!
same here.
I have now two hours playtime.
btw, i found my little meyer toroid with copperwire on it.
Was it Resistance Wire? if not try using Resistors for Laughs.
Its normal copperwire.
Stan said that it didnt matter.
He filed patents with resistance wire and with normal copperwire just to prevent other people copying and modifing his patent and make one their own.
the only thing the resistive wire does is that it become the load.. i tried with some nickel chrome wire when you connect the load the voltage drops inside the coil...
if your cell has 1 ohm for example and you have 99 ohm coil and you apply 100v to it it will have 1 v on the cell or so
thanks for some new insights into the technology.......
except if the capacitance is caused by the copper electron bounce on out side of wire
and changes which stainless
some thing that is not immediately obvious unless re making the exact round transformer vic design by Meyers
