Electronics => Best WORKING circuits for WFC => Topic started by: Steve on May 12, 2008, 11:05:51 am
Title: Frequency generator PLL driven with pulse control (Stans VIC)
Post by: Login to see usernames on May 12, 2008, 11:05:51 am
From eclipsed78
is here a nice PLL driven circuit.
Title: Re: Frequency generator PLL driven with pulse control (Stans VIC)
Post by: Login to see usernames on March 06, 2011, 17:02:51 pm
Found this schematic from some years ago.
Not sure if it works, but it looks ok.
Post by: Login to see usernames on March 06, 2011, 18:25:15 pm
There is an error in this schematic, in the resonant scanning circuit bipolar switches are needed like indicated in the first schematic and the 15 pin of the decade counter must be connected to the ground . The rest is pretty much the same as mine...
Post by: Login to see usernames on March 06, 2011, 22:57:15 pm
They all look the same, hahahahahahaha
Thanks man.
Post by: Login to see usernames on March 07, 2011, 02:36:31 am
I mean the Q8 and Q9 transistors.. hehe  but the first schematic is ok, is the same as mine one, but i tell you that i only found this when i had already solved the pll... so is coincidentally perfectly equal... but I prefer my new one.
Post by: Login to see usernames on March 07, 2011, 02:45:39 am
I'm constructing a new pll witch i'm going to use only high speed 5v htc chips and i'm going to solder the ics directly in the board to minimize the capacitance between the pins. My breadboard worked really strange.. I found that the potentiometer was broken but i decided to construct a soldered circuit cause i'm not sure if the problem was exclusively the potentiometer, i lost a couple of days.. ... The gate circuit i'm going to use the one i already have working... I will put everything in a closed box to act as a faraday cage.. to try have some more stability...
I need to buy some more pieces but i'm out of money and is carnival here all store are closed like in led Zeppelin song.
I condensed the pll the high speed nor gate the driver the voltage regulators and a frequency divider this board will have 1 potentiometer... It will also have the lock in indicator circuit all in the same board.
I'm thinking to use a connector where i will connect all the things that interacts with the circuit so i can easily take it out of the box like potentiometers leds inputs and outputs.
Lot of work here soldering... The board is 2inches X two inches.
Post by: Login to see usernames on March 07, 2011, 16:59:10 pm
I don't understand how the pulse indicator works; the signal from the feedback coil is rectified and fed into an opamp, doesn't it just mirror the input signal  into a TTL signal?
Post by: Login to see usernames on March 07, 2011, 17:22:18 pm
It is basically a clipping circuit connected to a opamp as schmitt trigger, generating TTL pulses.
http://personal.ee.surrey.ac.uk/Personal/H.M/UGLabs/briefs/d1.htm (http://personal.ee.surrey.ac.uk/Personal/H.M/UGLabs/briefs/d1.htm)
br,
webmug
Post by: Login to see usernames on March 07, 2011, 18:11:55 pm
The antiparallel diodes limit the voltage to a maximum of 0.7v and the resistors in series limit the current, so you can always get the same signal voltage, than the opamp clean up and amplify and balance the signal so you get a perfect stable and clean square wave signal..  this goes to pin 14 in the pll...
To test it is easy you simply pulse your primary (in saturation) and work in the circuit until you get the right signal for the pin 14...
Post by: Login to see usernames on March 07, 2011, 21:38:20 pm
Post by: Login to see usernames on August 06, 2014, 15:47:49 pm
another pll schematic
Post by: Login to see usernames on August 06, 2014, 15:55:36 pm
another one
